And it limits the size available for temporary data, which can be huge for large projects.Gale Andrews wrote:You could always experiment with using a RAM drive and see how much faster that was, but if there is a crash your data is gone.
Upper length bar playback problem [SOLVED]
Re: Upper length bar playback problem
rambomhtri
- Operating System: Windows 8 or 8.1
Re: Upper length bar playback problem [SOLVED]
Mark this problem as solved, cause in version 2.1.1 is SOLVED!!!!!
Thank you developers!
- Quality Assurance
I marked it [SOLVED].rambomhtri wrote:Mark this problem as solved, cause in version 2.1.1 is SOLVED!!!!!![]()
Many thanks to Steve who worked on this.
