Audacity 1.2.x and 1.3.x are obsolete and no longer supported. If you still have those versions, please upgrade at
https://www.audacityteam.org/download/.
The old forums for those versions are now closed, but you can still read the archives of the
1.2.x and
1.3.x forums.
Tapehead
Post
by Tapehead » Sat Jan 18, 2014 11:49 am
I want to delete the highlighted section in the image below and keep the other tracks in sync with the remainder of the now shortened track. (The delete works without having to crossfade the new join)
But if I apply sync lock and delete that sector it also deletes the end of the drum track below it which I don't want. If I don't use sync lock everything after the delete is thrown out of kilter.
How do I get around this?
- Quality Assurance
Post
by Gale Andrews » Sat Jan 18, 2014 1:12 pm
Demarcate the drum track as in its own Sync-Locked Track Group by putting it at the bottom of the project with a label track above it, and make sure the drum track is not selected.
First, Edit > Region Save.
Tracks > Add New > Label Track. The Label Track appears at the bottom of the project.
Click above Mute/Solo on the drum track and drag it to the bottom of the project (so the label track is above it).
Edit > Region Restore.
Now you can SHIFT-click on the Track Control Panels to select the restored region in all the tracks except the bottom one. You will see the Sync-Lock icon is not showing in the bottom track, so that track will not be affected by the deletion.
You could instead click in the name of the drum track and choose "Move Down" as needed. This preserves the region in the Timeline, so you don't need the region save and restore. 2.0.6 will have "Move Track to Bottom" and "Move Track to Top" commands in the Track Drop-Down Menu.
Tapehead
Post
by Tapehead » Sat Jan 18, 2014 1:51 pm
Easy when you know how!
Thanks a lot Gale, that's made my day!
- Quality Assurance
Post
by Gale Andrews » Sat Jan 18, 2014 3:54 pm
Gale Andrews wrote:Now you can SHIFT-click on the Track Control Panels to select the restored region in all the tracks except the bottom one. You will see the Sync-Lock icon is not showing in the bottom track, so that track will not be affected by the deletion.
Sorry, I should be completely clear that the only essential tasks are to deselect the drum track and to select
at least one of the tracks in the Sync-Locked Track Group above the drum track Group.
As you'll see, selecting just one of the tracks in the Group you want to delete from will enable the Sync-Lock icon in all the tracks in that Group.
Tapehead
Post
by Tapehead » Sat Jan 18, 2014 6:45 pm
Thanks, I'll use that refinement next time.
