The problem is that the driver may not be perfectly matched to your hardware (it may only be a generic Realtek driver like those you can get from the Realtek site).rambomhtri wrote:I know that not a newer driver means only improvements, but generally, the newer a driver it is better. So what's the problem of have a newer audio driver?That may not be a good thing, if Windows downloaded that driver of its own accord. You'd hope that Lenovo would post the latest correct audio drivers...
By the way, I've downloaded it from a driver updater I have.
You can (or should) be sure that the drivers on the Lenovo site are perfectly matched to your hardware.
It matters for other people reading this.rambomhtri wrote:Anyway, If you said that a newer/older driver is not gonna fix my delay, why does it matter?
Windows Update and third-party driver programs can and do find generic audio drivers rather than ones perfectly matched to your hardware. Driver program manufacturers often want to sell you their program by "proving" they can find new drivers for you.
If the "perfectly matched" drivers lack a required feature (such as stereo mix) then sometimes a generic driver that has the feature can be seen as an improvement, but 99 times out of 100 you want to get audio drivers for a branded computer from the computer manufacturer's site.
