filter
andreas84
filter
Post by andreas84 » Sun Jan 12, 2014 9:11 pm
it would be good to display the filter different or categorize them the way it is now is really not good
waxcylinder
Re: filter
Post by waxcylinder » Sun Jan 12, 2014 10:59 pm
You what .... ??? :?
andreas84
Re: filter
Post by andreas84 » Mon Jan 13, 2014 12:52 am
Hello,
Use the filter Amplify on any audio, then use the filter Wave shaper (at the very bottom) and then use auto duck and tell me how long you spend scrolling...
Re: filter
Post by steve » Mon Jan 13, 2014 12:56 am
The list is in alphabetic order. Open the menu and type the first letter of the effect name to quickly scroll to it. If there is more than one effect with the same first letter, press the same key again to move to the next one.
waxcylinder
Re: filter
Post by waxcylinder » Mon Jan 13, 2014 9:24 am
Ah, now I see - there is a feature request and proposal on the Audacity wiki relating to this: http://wiki.audacityteam.org/wiki/Propo ... gorization
Would you like us to add your vote?
The other thing you can do with the later versions of Audacity is to set keyboard shortcuts for effects that you commonly use - see: http://manual.audacityteam.org/o/man/ke ... ences.html
Re: filter
Post by Gale Andrews » Tue Jan 14, 2014 7:19 pm
I'll count it as a vote for "Effects categorisation" if andreas84 does not reply again.
