Vaughan proposed removing the ability to add label at selection when playing and recording, so there would be only one Add Label command in the Tracks Menu - it would add a label at the selection when there was no playback/recording, and add a label at the playback/recording position when playing/recording.Robert J. H. wrote:I also wonder if Ctrl-b couldn't have another functionality during playback, for example:
- You start playback
- you set the region start with the normal "Set (or Extend) Left Selection" key (don't know what it is on en English keyboard, I've assigned "L")
- You press Ctrl-b to create a region label that finishes at the current position.
- The selection start is automatically set to this new position, in order to create region labels continuously.
- white space is simply created by pressing Set (or Extend) Left Selection" later during play back.
Technically, Ctrl-b during play back would simulate three keystrokes at once:
- "Set (or Extend) Right Selection"
- "Set (or Extend) Left Selection"
- Ctrl-b as in the stop mode.
We've talked him out of that, though I suggested we could do what he wanted if we added a new shortcut that completes the selection during playback (like right bracket does) but also creates a label for that selection. The shortcut might be SHIFT + right bracket. So it's like your idea but not using CTRL + B.
I also suggested that to get rid of add label at selection during playback/recording, we'd also need a modified click to label the click point, and the same modifier would label a region when you release the drag.
A few people have asked about creating contiguous region labels when playing, but I'm not sure that CTRL + B (if we keep it) should ever set the selection start to other than the start of the selection.
Before I suggested that SHIFT + right bracket might complete a selection and draw a label, I'd suggested when there is already a selection region during playback, SHIFT + right bracket might provide an alternative to right bracket by drawing a selection starting from the end of the current region to the point where you pressed SHIFT + ].
That sounds like your idea too, but I don't think that should replace the current right bracket action of extending a current selection during playback. Am I misunderstanding, and you're saying that right bracket would still act as now when there is already a selection?
Either way, does one really need contiguous region labels when point labels act as contiguous track delimiters for Export Multiple?
