Gale, no I'm just using the stock binaries for Windows, I don't have any compilation capability on my Windows machine, just recording software.
I use Linux on my everyday machine, and if Audacity was multi channel capable in both directions, I'd switch my audio computer to use it too probably.
8 outputs audio card
LowBassDub
