8 outputs audio card
Hello,
I'm thinking of buying a 8 outputs audio card on usb to mix some little projects on a Soudcraft mixer. Can Audacity send one track per output if there is no more than 8 tracks in a project?
regards,
Pfeuh
regards,
Pfeuh
- Quality Assurance
Re: 8 outputs audio card
Audacity can export multi-channel audio files if you enable "Use custom mix" in Import / Export Preferences, but it can only play tracks mixed down to stereo.pfeuh wrote:Can Audacity send one track per output if there is no more than 8 tracks in a project?
Hello,
Thank you for the answer, but there is a little misunderstanding. I didn't talk about exporting tracks, but about routing each track to a different output of the sound card and route each output of the soundtrack to an analog input of a real mixer. I'm afraid that I understand your answer:
Regards,
Pfeuh
Does it means that what I would like to do is not possible? In this case, I will have to export a collection of wave file as you said and use an other mixer application able to dispatch these waves on several output of the sound card. Have you ever heard about such an open source application?but it can only play tracks mixed down to stereo.
Regards,
Pfeuh
Audacity cannot currently do that. The output from Audacity is mono or stereo.pfeuh wrote:Thank you for the answer, but there is a little misunderstanding. I didn't talk about exporting tracks, but about routing each track to a different output of the sound card and route each output of the soundtrack to an analog input of a real mixer.
Do you want to vote for "multi-channel playback" as a new feature?
It means that it is not possible with Audacity.pfeuh wrote:Does it means that what I would like to do is not possible?
Audacity can create multi-channel audio files (see http://manual.audacityteam.org/o/man/ad ... tions.html) but it cannot itself output audio to more than 2 channels. If you have an audio player that can output to multiple channels than it should be able to play multi-channel files created by Audacity.
- Quality Assurance
I'll count this as a vote for "multi-channel playback" as a new feature unless pfeuh says he wants Audacity to always mix down output to mono or stereo as now.steve wrote:Do you want to vote for "multi-channel playback" as a new feature?
You are welcome. Audacity is my favorite tool for recording and working on sounds. But on this particular feature, it could be enhanced a lot.Gale Andrews wrote:[I'll count this as a vote for "multi-channel playback" as a new feature
Regards,
Pfeuh
You can probably create an 8-channel WAV file and play it through a 7.1 Channel soundcard (with the player software of your choice), but it sounds like a tricky thing to set-up & configure the hardware & software.I'm thinking of buying a 8 outputs audio card on usb to mix some little projects on a Soudcraft mixer. Can Audacity send one track per output if there is no more than 8 tracks in a project?
You could mix with Audacity.... If you have 8 separate audio files, the standard approach would be use use a DAW and mix digitally "in the box" (digitally with software). Besides cost savings, you also avoid the quality loss that happens with analog mixing/processing. And, you can automate your mixing (programming volume changes, and other changes) during the mixdown. Mixing is done by summing (addition). Analog mixers are built-around a summing amplifiers.... Computers are really good at addition!
Pros often use a "control surface" that looks like a mixer, but actually controls the DAW software. (Control surfaces can be very expensive.) Some pros do like to use an analog mixer, but they've got all kinds of expensive high-quality multi-channel equipment, and mixers with motorized faders, etc... And IMO, it's kind of goofy!
A DAW also allows you to use all kinds of effects (compression, reverb, EQ) seperately applied/controlled on each channel.
The downside to a DAW is that it's quite a bit more complex than an audio editor (like Audacity).
REAPER ($60 USD) is a popular with hobbyists and home studios, or there are other popular choices. The nice thing about REAPER is that you get the whole thing for $60 (pros have to pay more for the license, but there is no extra-cost "pro version" or extra-cost add-ons), and they don't stick-it-to-you for upgrades. Of course, you can add expensive 3rd-party plug-ins if you wish.
Hello,
Regards,
Pfeuh
I do it very often... But without equalisation, without reverberation, compression and other special effects which are destructive in the current version. For 300 euros, you can buy a Soundcraft mixer with a Lexicon effect, a 3 band equalization with a medium parametric, it's better than all the daws of the world. A 8 outputs sound card is much cheaper. I'm from the old generation, I like to feel the real world on my fingertips. I also like the mixed signal to cross a real tube amplifier. I know that the new generation prefers to do everything on a smartphone.DVDdoug wrote:You could mix with Audacity....
It could be a solution, I will try it. But the best for my problem should be to route the tracks on several analog outputs, in Audacity or in another sound application. My job is software programmer in industrial embedded sensors, I realize that adding this feature is totally possible.DVDdoug wrote:REAPER ($60 USD) is a popular with hobbyists and home studios, or there are other popular choices. The nice thing about REAPER is that you get the whole thing for $60 (pros have to pay more for the license, but there is no extra-cost "pro version" or extra-cost add-ons), and they don't stick-it-to-you for upgrades. Of course, you can add expensive 3rd-party plug-ins if you wish.
Regards,
Pfeuh
LowBassDub
Way back in 2008, I had the same issue, M-Audio1010 card, Soundcraft mixer, and eight tracks of audio that I wanted to process in the analog realm. I ended up processing the tracks a pair at a time, running them through the board and back into Audacity, so I had eight original tracks and eight processed tracks, then I adjusted the levels of the processed tracks and mixed them 'in the box'.
After that experience I moved onto Protools, and then Reaper, and then finally came back to Audacity last year, as I was tired of having to 'arm tracks' and 'select input device' when all I wanted was a giant record button that starts up recording eight tracks at once. I came across this thread when I was trying to figure out if they had finally put multi channel playback capability in Audacity or not. I'm guessing not, so make this my vote to add this feature.
I've done, and am doing, this 'mix in the box', and I'm not a fan of it, EQ is nice to tweak, and faders are nice to slide, and MIDI/USB controllers aren't the same.
It would also be nice if, even if your interface has eight channels + 2 ADAT + 2 Mix, if you could select 4 channels in the preferences and have it record just the first four channels. After every recording I have to close all the twelve tracks I didn't use before saving to avoid wasting disk space.
Hello,
I bought the Soundcraft mixer, it's a real pleasure to use it. I use an old Cubase to send the tracks (same way as you, 4 stereo bus), but it's really boring to "export multiple" from Audacity... If some tracks are not starting from instant zero, you have to add a filled with zeros stuff before anything, then you have to synchronise the tracks (Ctrl-A J Shift-K Ctrl-T), after you have to configure all volumes and panpots to zero and then you can export... It's not finish... if you save this project, the audacity mix is lost. It's a kind of punishment but I don't known my fault.
It would be so cool to have this multiple outputs option in Audacity.
