I would expect that for those "fringe cases" there are multiple workarounds, none of which will take more than 3 seconds.Gale Andrews wrote:Obviously it means that the control for the final label would be removed, but I think that control is of use in fringe cases.
For example, if you just want a point label at the end of the track: K, then Ctrl+B takes me less than 1 second.
When labelling tracks with point labels for Export Multiple, a "final label" at the end of the track is not be required. There is nothing to export beyond the end of the track.
At present a final label will probably be required in the example shown in my previous post. In this example case I think "the right thing to do" is to add a label at 4 seconds.
There may be one or two exception, but for the benefit of the masses I think this effect should be able to do "the right thing" without that extra control.
If you think of any specific use cases that are not covered by the plug-in doing "the right thing" then we can reconsider, but otherwise I'd much prefer to avoid a control that sometimes appears to not work.
