Dimension Engineering DE-ACCM3D Accelerometer
Did you buy a new mixer? Do you need advice? Post here.
breadhead
Post by breadhead » Fri Jan 03, 2014 8:05 pm
Hello everyone,
I am a new member and this is my first post. Does anyone know how I can get the data from the DE-ACCM3D accelerometer into audacity for analysis. I am trying to determine vibration level of a mechanical device which also incorporates a small electric motor. Any help would be greatly appreciated. Thanks in advance.
Jim
Re: Dimension Engineering DE-ACCM3D Accelerometer
Post by steve » Fri Jan 03, 2014 8:13 pm
Topic moved to "Recording Equipment" as it is primarily a hardware question.
Have you tried coupling the output to a sound card input via a capacitor. A fairly large value will be required as the frequency range of the accelerometer is quite low. A couple of hundred microfarads will probably do the job. If you use a polarised capacitor, check for DC before connecting the capacitor.
