As a naive user I would not look in the Analyze Menu for track splitters that split on either silence/sound or split into regular sections.steve wrote:Below are some possible candidates for a Tools menu.Gale Andrews wrote:I support having a "Tools" Menu, but you don't seem to be persuading the developers. Nyquist Workbench should be in the "Tools" menu but there should be at least three released items in that menu to justify adding it. If we released "Quick Calculator" what else would go in "Tools"?
As a naive user I might look in Generate for a plug-in that I knew generated labels, but I don't think that is a solution. Generate is for audio.
On the whole, I don't see a strong case for moving those. Quite related to files.steve wrote: [*]Edit Metadata. (it is related to file in/out, but is not actually a "file command").
[*]Check Dependencies. (While there are practical considerations for keeping this in the File menu, it is really a "tool" for checking the project dependencies)
Transport is about audio devices. I would move Audio Device Info into Transport with Rescan Audio Devices.steve wrote: [*]Rescan Audio Devices. (Not about "transport").
Since Apply Chain can be applied to Files, and Edit Chains must be with it, it has a relationship to File Menu. I would like ultimately to see it in an "Automation" menu with macro recording and editing in the other menu items. Until then there is a weak case for it to be in a Tools menu.steve wrote: [*]Edit Chains / Apply Chains. (Again, not really a "file command").
[*]Mixer Board?
Putting Mixer Board in Tools similarly seems only a half-improvement. I think it would be most discoverable in Tracks.
+1steve wrote: [*]Run Benchmark.
[*]Screenshot Tools (the name says why).
"Nyquist Reference" should be in "Help".steve wrote: Non-shipped features:Other possible features:
- Quick Calculator.
- Robert's "Nyquist Reference" plug-in (though could perhaps be in the Help menu).
- bpm Calculator. http://forum.audacityteam.org/viewtopic ... 33#p196933
- Beat Per Minute labels. http://forum.audacityteam.org/viewtopic ... 21#p155621
- Envelope Tool options (linear, exponential, other fade types)
- Tempo mapping. (http://en.wikipedia.org/wiki/Tempo_map)
- Sound font manager for MIDI to Audio rendering.
- Channel mapping for device in/out.
- Effects manager.
- CD ripper / burner.
I don't think at this stage that a CD ripper/burner is likely now unless we have a specialised Audacity for bundling with USB playback devices. My support for CD tools has cooled off, and so have user requests for it. Perhaps the fall off of interest in commercial CD's is the reason. I do think Tools would be the place for a video editing window or other tools which bridged to other apps.
Anyhow I would expect agreement on Screenshot Tools and Run Benchmark in a new Tools Menu, so we don't have to add much else. I'm OK with adding the two calculators. It still leaves a question about whether any kind of track splitter would be easier found in Tools.
