Overdub Problems
Please state:
Please state:
JccOldTime23
Re: Overdub Problems
They are plugged into the headphone jack on the side of the laptop.
JccOldTime23
On further testing the headphone problem is not with audacity. All of a sudden my headphone jack doesn't work at all. Headphones work fine on my keyboard so I know it's a laptop issue. That's just great. I guess this project will definitely have to be single tracked now.
Josh
Josh
