Thanks, I appreciate what you say, but every time I open Audacity to record I have this problem, I have tried recording from different sources and the result is always the same. I have tried different playback and recording devices set for Audacity still no difference, but by changing the sample rate after recording has worked 100% of the time for me. Maybe I have set something wrong, or maybe the system itself is set wrong I don't know. All I know is it works for me (so far lol). I even tried Ocenaudio to record my streams no issues, There's obviously a conflict on my machine somewhere, but i will take on board what you have said and keep my eye on it. Again many thanks for you inputHowever do note that the solution of changing project rate is not foolproof and has just as often been reported not to work (or only to work sometimes) which is probably why none of us mentioned it.
Assuming you are choosing the pulse device to record from in Audacity, pulse should be able to handle the conversions without speed changes. But if that handling does not work and for example you have a 44100 Hz only device and the stream is 48000 Hz, you may see the problem you describe.
Recorded audio sounds slow
Please state:
Please state:
rebelwriteruk
Re: Recorded audio sounds slow
- Quality Assurance
Set Rate will always change the length and playback speed by the proportion relative to the original rate (if you can find the correct change to make). If not you can experiment with Effect > Change Speed... .rebelwriteruk wrote:Thanks, I appreciate what you say, but every time I open Audacity to record I have this problem, I have tried recording from different sources and the result is always the same. I have tried different playback and recording devices set for Audacity still no difference, but by changing the sample rate after recording has worked 100% of the time for me.However do note that the solution of changing project rate is not foolproof and has just as often been reported not to work (or only to work sometimes) which is probably why none of us mentioned it.
All I'm saying is that changing the project rate before recording may still leave you recording at the wrong speed, whatever rate you choose. Sometimes though, changing the project rate before recording might let you record at the correct speed, avoiding the need to use Set Rate.
