correction: WMA to WAV
Sorry, I did not give the info necessary. I would like to convert WMA files to WAV. Just started on Audacity 2.0.5. and using Windows 8. After editing, will use Adobe's Premier Elements. Again, thanks !!
Re: correction: WMA to WAV
Is this part of an earlier post? I didn't see anything associated with you. Koz
WMA will apparently open up in Audacity with the FFmpeg libraries installed. After the work opens, File > Export: WAV (Microsoft).
Download FFmpeg here http://manual.audacityteam.org/o/man/fa ... tml#ffdown .
Reason: direct link to FFmpeg
thanks, Koz. However, I don't understand. Could you bring your information down to the basics, please.
-Dave
-Dave
Please avoid double posting.
There are other answers in your duplicate post here: http://forum.audacityteam.org/viewtopic ... 76#p231176
I'll lock this topic to avoid confusion.
