I want to sync the existing six tracks I have and drag them all forward on the timeline to be able to insert a new lead-track content before them on the timeline.
The manual says tracks > sync lock or use sync-lock button. I don't see either on my Audacity 2x Gui?
Sync lock question.
Re: Sync lock question.
What is the exact version number of your Audacity installation? (look in "Help > About Audacity")Tapehead wrote:The manual says tracks > sync lock or use sync-lock button. I don't see either on my Audacity 2x Gui?
Thanks.
2.02
Update:
Been messing around and have just noticed that when a project is loaded I don't see sync-lock
When I load Audacity empty I do, but this doesn't carry over to reloading the project.
2.02
Update:
"Sync Lock Tracks" is the 10th item in the "Tracks" menu.
The Sync lock icon looks like a clock face as shown here: http://manual.audacityteam.org/o/man/ed ... .html#link
Details about how Sync Lock works are here: http://manual.audacityteam.org/o/man/sy ... roups.html
The current version of Audacity is 2.0.5 which is available here: http://audacityteam.org/download/windows
Thanks, I updated to the latest version and it is fine now!
