Audacity 2.0.3 can't find input...Please help!
MrServiceMan
I am attempting to use Audacity 2.0.3 for the first time. I was following a tutorial that seemed to be going well until I was instructed to select the input device from the drop down menu. It was then that I realized that Audacity is not recognizing the microphone as being present. I am using a USB microphone/headset combination. My computer recognizes both the head set speakers and the microphone. They are working fine. I am using the windows-7 operating system. Can someone please tell me if there is some setting that I need to make to make the mic visible to Audacity……Thank you.
Re: Audacity 2.0.3 can't find input...Please help!
Just to take the obvious first. Audacity looks for microphones when it starts. Restart Audacity with the headset plugged in.
I have been able to record my USB headset just fine. Attached.
- Attachments
- LogitechHeadset.mp3
- (325.71 KiB) Downloaded 93 times
MrServiceMan
