How to concatenate two audio files
TonyRolfe
Post by TonyRolfe » Sat Dec 07, 2013 2:33 am
Win 7 x64 with all updates, Audacity 2.0.5 and the .exe installer.
I've hunted through the help and the FAQ but I can't find out how to do this.
I have two stereo audio files each about 2 minutes long. They should have been one 4 minute file. I'm sure there must be a way to put them together again. I've tried drag and drop but that gives me 4 tracks each about 2 minutes long.
Any advice would be appreciated
Thanks
Tony
Re: How to concatenate two audio files
Post by kozikowski » Sat Dec 07, 2013 3:08 am
Import both sound files. They should appear one above the other and play at thee same time. Double click in the blue waves of the bottom one to select it. Control-C copy. Double Click The top file > End > Control-V Paste.
Back on the bottom track, press MUTE to keep it quiet.
Play and see how you did.
TonyRolfe
Post by TonyRolfe » Sat Dec 07, 2013 4:08 am
Thanks Koz
That worked perfectly
Cheers
Tony
Post by Gale Andrews » Sat Dec 07, 2013 5:08 am
TonyRolfe wrote:I've hunted through the help and the FAQ but I can't find out how to do this.
What would have made that FAQ easier to find? See How do I combine two files into one longer file? . Built-in search would help I guess, but searching for "concatenate" would not have found it.
Post by kozikowski » Sat Dec 07, 2013 5:21 am
Import/Append would not have done it, either. Is there a way to "associate" a list of search terms with a wiki submission? Koz
Post by Gale Andrews » Sat Dec 07, 2013 7:42 am
kozikowski wrote:Import/Append would not have done it, either. Is there a way to "associate" a list of search terms with a wiki submission? Koz
Quite hard. Wiki gives us no control over keywords without installing extensions, and in any case search engines tend to downgrade the importance of keywords these days.
The script that "dumps" the development Manual to make the Manual for each release removes HTML comments which a built-in search would see.
It's possible using some kind of server script to make a list of keywords and serve FAQ's based on a user searching for those keywords. This would potentially be very useful if applied to the online Manual or even the Forum, but it's definitely more complex to make this play nicely with the Wiki and Forum software than if it was a straight web site.
gurky
Post by gurky » Fri Jan 03, 2020 3:21 pm
I tried this but have my doubts. The first file is about 12 Mb, the second 4 Mb. After exporting,
the resulting file is about 22 Mb. This can't be right. I suppose I should listen to the result.
