Building and customizing Audacity from the source code.
Paul L
Post
by Paul L » Wed Dec 04, 2013 12:47 am
I followed these instructions
http://audacity.googlecode.com/svn/auda ... ompile.txt for setting the environment variable for the wx widgets.
I get this:
2>------ Build started: Project: Audacity, Configuration: Debug Win32 ------
2>Compiling...
2>AudacityHeaders.cpp
2>c:wxwidgets-2.8.12includewxplatform.h(196) : fatal error C1083: Cannot open include file: 'wx/setup.h': No such file or directory
So Visual Studio is finding platform.h, but then what? What is missing from my include path?
Edgar
- Forum Crew
Post
by Edgar » Wed Dec 04, 2013 2:04 am
Unfortunately, this is a common problem. There are a couple of solutions but the best one is to go back to the very beginning of the compilation steps. Copy the setup.h file which is provided by Audacity into the location suggested in the compile instructions which are located in the win folder in the file compile.txt. Thereafter recompile wxWidgets, and then copy all five of the wxWidgets DLLs (or 10 if you are going to do Release and Debug) into their appropriate locations. Now try compiling Audacity again.
If you need excruciatingly detailed step-by-step instructions read them here:
http://www.hometownband.org/Audacity/Co ... acity.html
you can skip down past the part which deals with installing MS VC++ 2008 and the wxWidgets but pay particular attention to the instructions about setup.h. If you have any additional questions don't hesitate to ask!
Paul L
Post
by Paul L » Wed Dec 04, 2013 2:19 am
are the instructions correct? Rather than copying to C:wxWidgets-2.8.12includewxmsw, should it instead go to C:wxWidgets-2.8.12includewx ? I have done the latter and now my build of Audacity has resumed.
Now I see
2>LINK : fatal error LNK1104: cannot open file 'wxbase28ud.lib'
A link error is progress! Compilation is complete.
Paul L
Post
by Paul L » Wed Dec 04, 2013 4:49 am
rebuilt wx_dll with the correct configuration, now running. Thanks!
Edgar
- Forum Crew
Post
by Edgar » Wed Dec 04, 2013 6:52 am
Paul L wrote:are the instructions correct? Rather than copying to C:wxWidgets-2.8.12includewxmsw, should it instead go to C:wxWidgets-2.8.12includewx ? I have done the latter and now my build of Audacity has resumed.
As I said there are multiple solutions; the one you found may not be "correct" but might work unless you are also trying to build other wxWidgets projects like the wxWidgets examples. Technically, I think it really does need to be in wxWidgets-2.8.12includewxmsw and then during the build process for wxWidgets it might get copied or re-created in wxWidgets-2.8.12includewx. I'm not sure but I think the version that ends up inwxWidgets-2.8.12includewx is generic and the version that is in wxWidgets-2.8.12includewxmsw is Windows specific.
Paul L
Post
by Paul L » Wed Dec 04, 2013 8:29 am
I had some puzzling build errors. I redid my build of wx from scratch (and I mean repeating the download) and followed things to the letter this time. I no longer question the instructions.
