FLAC files and Level
Feedback and Reviews for Audacity 2.x
This board is ONLY for general feedback and discussion about Audacity 2.X.
If you require help, or think you have found a "bug", please post on the forum board relevant to your operating system.
WeirDave
Post by WeirDave » Tue Dec 03, 2013 11:07 pm
Hello,
I ran a test on the same file where I saved the file using Export Multiple > FLAC 16bit Depth with the Level on 5 then the Level on 8. Although your help files say the file size will not be affected I noticed the file size was indeed different between the two types. Perhaps I do not understand the process? Which makes the "best file"?
Strangely to me anyway the The Level 8 file size was 34,520 KB while the Level 5 was larger at 34,740 KB.
I am ripping vinyl and would like the use the best settings I can.
Please advise,
R David Paine III / WeirDave
WeirDave
Re: FLAC files and Level
Post by WeirDave » Tue Dec 03, 2013 11:15 pm
I found the following article which seemed to make sense:
http://superuser.com/questions/158402/h ... pped-music
Post by steve » Tue Dec 03, 2013 11:24 pm
WeirDave wrote: I ran a test on the same file where I saved the file using Export Multiple > FLAC 16bit Depth with the Level on 5 then the Level on 8. Although your help files say the file size will not be affected I noticed the file size was indeed different between the two types
Could you tell us where it says that so that we can correct it.
WeirDave
Post by WeirDave » Wed Dec 04, 2013 3:06 pm
I want to say it was the wiki but if you say it wasn't then I may have misread the information. The manual that ships with the product is also vague:
"Level: The amount of compression used to create the FLAC file. The level settings range from 0 to 8, with 0 being fastest and 8 giving the most compression. The default level is 5. As all compression levels are lossless, the level chosen makes relatively little difference to the exported file size, but makes a considerable difference to the speed of encoding. Typically, encoding at compression level 8 is three to four times slower than level 0. "
Sorry for the trouble, just trying to help. :)
WeirDave
Post by steve » Wed Dec 04, 2013 8:51 pm
Thanks for the follow-up WeirDave.
My take on this:
WeirDave wrote:The Level 8 file size was 34,520 KB while the Level 5 was larger at 34,740 KB.
That works out as about 0.6% difference in size, which I would say is "relatively little difference". This is a big contrast to lossy formats such as Ogg or MP3 where high quality settings produce considerably bigger files than low quality settings.
