Don't like the blue lines... (SOLVED)
Feedback and Reviews for Audacity 2.x
This board is ONLY for general feedback and discussion about Audacity 2.X.
If you require help, or think you have found a "bug", please post on the forum board relevant to your operating system.
WayneP
Post by WayneP » Sun Nov 24, 2013 3:38 pm
Must have clicked on something I didn’t mean to, but for some reason the audio tracks suddenly all have a thin, horizontal blue stripe at the top and bottom, with broad dark and light gray stripes between them. When I try to highlight a section to do some editing, the highlight only shows up in the dark gray section of the broad light/dark gray stripes. Don’t know how this happened, but how do I turn it off?
Regards,
Wayne
Reason: marked as "Solved" and locked thread
Re: Don't like the blue lines...
Post by steve » Sun Nov 24, 2013 6:37 pm
You may have inadvertently selected the "Multi-tool" http://manual.audacityteam.org/o/man/multi_tool.html
To get back to the normal "Selection Tool" (http://manual.audacityteam.org/o/man/au ... ction.html), press the F1 key.
WayneP
Post by WayneP » Sun Nov 24, 2013 11:07 pm
Here is a screen shot, if that helps
Audacity screen shot reduced.jpg (103.36 KiB) Viewed 4825 times
WayneP
Post by WayneP » Sun Nov 24, 2013 11:08 pm
That took care of it, thanks!
