Audacity 1.3.6 -- whistles when exporting to MP3
dante_bothermy
Post by dante_bothermy » Sat Dec 06, 2008 9:35 pm
I'm transferring LPs to MP3 files.
When I export the files to MP3s, there's a distracting high-pitch whistling sound.
-- exports to WAV files don't have the problem
-- exports using version 1.2.6 don't have the problem
I have had occasional similar problems using LameDrop.
Any advice? Could it be the settings I use to export? (There aren't many I can control!)
Thanks.
waxcylinder
Re: Audacity 1.3.6 -- whistles when exporting to MP3
Post by waxcylinder » Sun Dec 07, 2008 12:03 pm
What export bitrate are you using? Have you tried setting a higher bitrate?
And what happens if you use an external converter program to create your MP3s?
TSMusic
Post by TSMusic » Tue Dec 09, 2008 9:37 pm
I've been having problems that I finally tracked down today to the MP3 export. I have the bit rate set to 128 and my exported file sounds like crap. I downloaded a trial version of MP3 Converter Simple and it works just fine. Night and day difference between the sound quality at the same bit rate. I had originally thought it was something in my song that was causing it but, I recorded a new song today and had the same #$&$(&%#&!!*(%)_Q#_Q## problem. So that's when I went to the different program (which is built around Lame as well).
FWIW
Tony
Art & Lutherie Cedar Folk CW 6 String Acoustic
Pre-Martin Goya 12 String
Vestor Bass
And a bunch of other ends and odds!
http://www.tonyseomusic.com/
http://www.myspace.com/tonyseomusic
http://www.soundclick.com/tonyseo
Post by steve » Tue Dec 09, 2008 10:05 pm
There has been a spate of problems with LAME in Audacity recently - Unlike other MP3 encoders, LAME is still being developed. I think that for a while the Audacity web site was linking to Lame v 3.98 but this had some problems, so they have gone back to v.3.97
The current version of Lame is 3.98.2 which includes some bug fixes since v.3.98 - I don't know if anyone has tried that version. (I'm using 3.98.0 on Linux and it seems fine).
TSMusic
Post by TSMusic » Tue Dec 09, 2008 10:32 pm
I poked around on the systems here and found that one piece of software had installed a late version 3.9.6 so I tried that....
It works...grrrrrrrrrrrrr. If I spent a minute, I must have spent 25 hrs trying to track down the source of the problem, reprocessing the MIDI tracks, re-recording the guitar parts, etc etc etc.
Needless to say, I opened up a big old bottle of CUSS on this one.
Thanks
Tony
Vestor Bass
dante_bothermy
Post by dante_bothermy » Wed Dec 10, 2008 2:47 am
waxcylinder wrote:What export bitrate are you using? Have you tried setting a higher bitrate?
I just upped the bitrate from 128 or 256 to 1024 and the whistling is still there. and I lowered it too,. No change
The external converter from WAV to MP3 (LameDrop) works just fine. No whistling
dante_bothermy
Post by dante_bothermy » Wed Dec 10, 2008 3:11 am
The crazy thing is that when I take the files recorded in Audacity 1.3.6 and export them using Audacity 1.2.6, everything works fine.
So I guess that's my answer, record on 1.3.6 (because 1.2.6 crashes too much) and export from 1.2.6 (because 1.3.6 distorts too much).
Simple, Neh?
:x :x :x
TSMusic
Post by TSMusic » Wed Dec 10, 2008 3:16 am
dante_bothermy wrote:The crazy thing is that when I take the files recorded in Audacity 1.3.6 and export them using Audacity 1.2.6, everything works fine.
Simple, Neh?
:x :x :x
Check the version of lame_enc.dll you are using. Or just look at the files, if there is a difference in size, you have 2 different versions. Rename the one you are using with 1.3.6 to something else and copy the one in from 1.2.6.
Tony
Vestor Bass
