Input level
Please state:
gurky
Input level
Post by gurky » Fri Nov 22, 2013 9:20 am
I am trying out using Audacity on my Thinkpad laptop running under Linux.
I plugged a sound source into the correct socket and started Audacity, but
it did not register any sound.
I assume I have to tell it where to look for it - how do I do that? I tried the
little menu on the input bars, but nothing works.
Thanks for any suggestions.
Re: Input level
Post by steve » Fri Nov 22, 2013 1:29 pm
gurky wrote:running under Linux.
Which Linux distribution?
gurky wrote:I plugged a sound source into the correct socket
What sound source and what socket?
gurky wrote:I assume I have to tell it where to look for it - how do I do that?
In Audacity, use the recording input setting in the device toolbar.
Depending on your set-up you may need to also configure the sound system.
gurky
Re: Input level
Post by gurky » Fri Nov 22, 2013 1:39 pm
Thanks all. I will check for the device toolbar. The Linux version is Suse 12.2, and
the sound source is the headphone output of a cassette recorder. There is a small
red socket on the side of the laptop and that's where I plugged the cable in.
Re: Input level
Post by steve » Fri Nov 22, 2013 1:48 pm
gurky wrote:There is a small red socket on the side of the laptop and that's where I plugged the cable in.
On a lot of laptops the only audio input is a microphone socket.
Microphone inputs are unsuitable for anything other than connecting a microphone because they are too sensitive and usually mono. When you get this working, if the sound is very loud and distorted then you will probably need to get a USB audio interface that has stereo, line level inputs. I use a Behringer UCA 202 because it is cheap with very good sound quality. There are many alternative products.
