wont recognize my akai interface
psalomon
Post by psalomon » Mon Nov 18, 2013 10:44 pm
i am trying to use an Akai Pro EIE (electronic interface expander), downloaded the sound driver and everything... audacity wont recognize or discover it so i cant use it. how can i get it to be seen by the program so that i can select it as my sound driver???
Re: wont recognize my akai interface
Post by steve » Mon Nov 18, 2013 11:05 pm
Ensure that the Akai is connected to the computer and recognised by Windows before you open Audacity.
If you start Audacity first you will need to "Rescan for audio devices" (Transport menu) after the Akai has been recognised by Windows.
psalomon
Post by psalomon » Mon Nov 18, 2013 11:39 pm
yeah it was being recognized by windows, there's a "panel" that is installed with the sound driver and it shows whether or not is picking anything up. It works fine with wavepad sound editor but i rather use audacity so im frustrated. I will try to rescan for it though and see if it can recognize it
Post by steve » Mon Nov 18, 2013 11:47 pm
For the "host" setting in the device toolbar, try the MME option - that is usually the most compatible.
If still no joy, select "Audio device info" in the Audacity help menu and copy and paste the contents into your reply. That will tell us if Audacity can see your device at all.
psalomon
Post by psalomon » Tue Nov 19, 2013 12:05 am
yeah i dont see it here
Code: Select all
Default capture device number: 1
Default playback device number: 4
Device ID: 0
Device name: Microsoft Sound Mapper - Input
Host name: MME
Input channels: 2
Output channels: 0
Low Input Latency: 0.090000
Low Output Latency: 0.090000
High Input Latency: 0.180000
High Output Latency: 0.180000
Supported Rates:
Device ID: 1
Device name: Integrated Microphone Array (ID
Host name: MME
Input channels: 2
Output channels: 0
Supported Rates:
Device ID: 2
Device name: Stereo Mix (IDT High Definition
Host name: MME
Input channels: 2
Output channels: 0
Supported Rates:
Device ID: 3
Device name: Microsoft Sound Mapper - Output
Host name: MME
Input channels: 0
Output channels: 2
Supported Rates:
    8000
    9600
    11025
    12000
    15000
    16000
    22050
    24000
    32000
    44100
    48000
    88200
    96000
    176400
    192000
    352800
    384000
Device ID: 4
Device name: Speakers / Headphones (IDT High
Host name: MME
Input channels: 0
Output channels: 2
Supported Rates:
    8000
    9600
    11025
    12000
    15000
    16000
    22050
    24000
    32000
    44100
    48000
    88200
    96000
    176400
    192000
    352800
    384000
Device ID: 5
Device name: Primary Sound Capture Driver
Host name: Windows DirectSound
Input channels: 2
Output channels: 0
Low Input Latency: 0.120000
Low Output Latency: 0.000000
High Input Latency: 0.240000
High Output Latency: 0.000000
Supported Rates:
Device ID: 6
Device name: Integrated Microphone Array (IDT High Definition Audio CODEC)
Input channels: 2
Output channels: 0
Supported Rates:
Device ID: 7
Device name: Stereo Mix (IDT High Definition Audio CODEC)
Input channels: 2
Output channels: 0
Supported Rates:
Device ID: 8
Device name: Primary Sound Driver
Input channels: 0
Output channels: 2
Low Input Latency: 0.000000
Low Output Latency: 0.120000
High Input Latency: 0.000000
High Output Latency: 0.240000
Supported Rates:
    8000
    9600
    11025
    12000
    15000
    16000
    22050
    24000
    32000
    44100
    48000
    88200
    96000
    176400
    192000
Device ID: 9
Device name: Speakers / Headphones (IDT High Definition Audio CODEC)
Input channels: 0
Output channels: 2
Supported Rates:
    8000
    9600
    11025
    12000
    15000
    16000
    22050
    24000
    32000
    44100
    48000
    88200
    96000
    176400
    192000
Device ID: 10
Host name: Windows WASAPI
Input channels: 0
Output channels: 2
Low Output Latency: 0.003000
High Output Latency: 0.010000
Supported Rates:
    48000
Device ID: 11
Device name: Speakers / Headphones (IDT High Definition Audio CODEC) (loopback)
Input channels: 2
Output channels: 0
Low Input Latency: 0.003000
High Input Latency: 0.010000
Supported Rates:
Device ID: 12
Input channels: 2
Output channels: 0
Supported Rates:
Device ID: 13
Input channels: 2
Output channels: 0
Supported Rates:
Selected capture device: 1 - Integrated Microphone Array (ID
Selected playback device: 4 - Speakers / Headphones (IDT High
Supported Rates:
    8000
    9600
    11025
    12000
    15000
    16000
    22050
    24000
    32000
    44100
    48000
    88200
    96000
    176400
    192000
    352800
    384000
Available mixers:
Available capture sources:
0 - Master
Available playback volumes:
0 - PCM
Capture volume is native
Playback volume is native
Reason: code tags added
Post by steve » Tue Nov 19, 2013 1:05 am
My guess is that you have installed ASIO drivers for the Akai, but no "Windows" drivers.
Audacity cannot be shipped with support for ASIO due to licensing restrictions, so for Audacity to be able to use the device you must have Windows USB drivers installed for it.
I suggest that you check here to see that you have the latest drivers: http://www.akaipro.com/product/eiepro#downloads (2.9.55)
Then reinstall the drivers, following the instructions in the manual very carefully. it is often important to do things in the right order when installing drivers, so read the instructions before you start.
When it's all done, reboot the computer.
youreyeslie
Post by youreyeslie » Sun Jul 19, 2015 9:22 pm
the Akai EIE that is not pro, doesn't have drivers, or it contains its own. So it's not a driver issue. Audacity recognizes my Akai EIE but I can't figure out how to get it to record all 4 tracks simotaniously.
Post by steve » Mon Jul 20, 2015 10:01 am
You may need to set the "host" to "WASAPI" in the device toolbar and then set the "number of channels" to "4".
