Audacity sometimes records at wrong speed
smeezekitty
Sometimes when I record from a USB microphone, the recorded file plays back too fast.
It as if it was recorded with a lower sample rate than it is played with. The strange part is it sometimes works ok and others it is the wrong speed.
I can make it playable by changing the speed -66.6
I am using Audacity 2.0.5 but I experienced the same thing with Audacity version 1.3.x
Attached is an actual recorded file that has the problem.
- Attachments
- problem.zip
- (115.12 KiB) Downloaded 62 times
Re: Audacity sometimes records at wrong speed
Which one?a USB microphone
You're a lot closer than we are. What's common about the successes and failures? What did you change?sometimes works ok and others it is the wrong speed.
What's the show? "Thank you for checking in" suggests you are recording a Skype conference or other community activity.
Are you by any chance trying to record an Audacity session with a computer also running Skype? Skype doesn't share well. The session will be the very definition of "unstable."
smeezekitty
I should have been more specific. It is actually built into a logitech webcam (sorry don't know exact model)Which one?
I don't really know. Infact, I just tried it and it recorded properly.You're a lot closer than we are. What's common about the successes and failures? What did you change?
In all cases, I was using 44100 mono
It is recorded off of radio not skype.What's the show? "Thank you for checking in" suggests you are recording a Skype conference or other community activity.
Nothing that uses the camera or microphone running
OK. I'm building this in my head. You play a web radio performance to your speakers and then you make Audacity record from the web cam and that's your show. You have to be very quiet so the room noise doesn't get into the capture, right? There are other ways to do that, but if your computer is fast enough for live audio, that does work.
Speed may be important. You can get a very fast capture if the recording process was running too slow. That can happen if the computer is only able to perform the capture if it's not busy doing anything else.
Could the difference be that you have other things or programs running when you get the damaged shows? It could be something wacky like it stops working if you open the video portion of the webcam. If you leave it closed, everything's fine.
smeezekitty
Thanks for responding.kozikowski wrote:OK. I'm building this in my head. You play a web radio performance to your speakers and then you make Audacity record from the web cam and that's your show. You have to be very quiet so the room noise doesn't get into the capture, right? There are other ways to do that, but if your computer is fast enough for live audio, that does work.
I am recording from a physical radio. No playback at all on the computer. The room is reasonably quiet but I don't really need high quality anyway.
One thing I noticed is today I woke the system from hibernate, switched windows from firefox to audacity and started recording and ended up with a bad recording.
I then made a recording right after that and it was perfect.
My system should be fast enough with a Core 2 Duo @ 2.66GHz
- Quality Assurance
Does this radio have a headphones output? Does your computer have a line-in port (blue)? If so you may be able to connect the radio to the line-in and record from line-in.smeezekitty wrote:I am recording from a physical radio.
Try rebooting the computer. You can avoid reboots for some time with sleep or hibernate but ultimately you have to reboot.smeezekitty wrote:One thing I noticed is today I woke the system from hibernate, switched windows from firefox to audacity and started recording and ended up with a bad recording.
What version of Windows is it? Have a look at this question about sample rate mismatches, especially if you are on Vista or later http://manual.audacityteam.org/o/man/fa ... .html#sync .
Note that when you record with a USB webcam mic and play back with the built in sound card, you have two different devices which almost certainly won't have the exact same clock speed. And if the speed is different at some times than others, this suggests a drivers problem (probably with the built-in sound device). Make sure the web cam and especially the built-in sound device have their latest intended drivers. Please see http://wiki.audacityteam.org/wiki/Updat ... ce_Drivers .
smeezekitty
Yes, but then I couldn't listen to the output.Gale Andrews wrote:Does this radio have a headphones output? Does your computer have a line-in port (blue)? If so you may be able to connect the radio to the line-in and record from line-in.smeezekitty wrote:I am recording from a physical radio.
Meh I guess I will have to break down and reboot. I like to hibernate because I get everything set up how I like itTry rebooting the computer. You can avoid reboots for some time with sleep or hibernate but ultimately you have to reboot.
It is windows vistaWhat version of Windows is it? Have a look at this question about sample rate mismatches, especially if you are on Vista or later http://manual.audacityteam.org/o/man/fa ... .html#sync .
I am not worried about 100hz or less difference. The difference is 3x as if it is being recorded at 14700Hz.Note that when you record with a USB webcam mic and play back with the built in sound card, you have two different devices which almost certainly won't have the exact same clock speed. And if the speed is different at some times than others, this suggests a drivers problem (probably with the built-in sound device). Make sure the web cam and especially the built-in sound device have their latest intended drivers. Please see http://wiki.audacityteam.org/wiki/Updat ... ce_Drivers .
You are probably right, it is likely a driver bug but it is hard to say
All other sound plays the correct speed, even if imported with Audacity. It ONLY happens if recorded over USB.
- Quality Assurance
Yes you could. In Audacity, Transport > Software Playthrough (on/off). This will play the recording through your computer playback device.smeezekitty wrote:Yes, but then I couldn't listen to the output.Gale Andrews wrote:Does this radio have a headphones output? Does your computer have a line-in port (blue)? If so you may be able to connect the radio to the line-in and record from line-in.smeezekitty wrote:I am recording from a physical radio.
Are you recording a high quality sound like music, or is this something like a walkie talkie radio? If it's music, then headphones out of the radio to line-in of the computer will give you a much better recording.
It's only a suggestion if you want to record with the webcam. USB devices can benefit from reboot. Or at least, try unplugging the web cam and reconnecting it.smeezekitty wrote:Meh I guess I will have to break down and reboot. I like to hibernate because I get everything set up how I like itTry rebooting the computer. You can avoid reboots for some time with sleep or hibernate but ultimately you have to reboot.
Can you put the programs you want in your startup menu?
Then go through that link above about sync carefully. Recording the mic with Windows DirectSound host in Audacity, 44100 Hz or 48000 Hz project rate, both Exclusive Mode boxes checked in Windows Sound Control Panel could solve it.smeezekitty wrote:It is windows vistaWhat version of Windows is it? Have a look at this question about sample rate mismatches, especially if you are on Vista or later http://manual.audacityteam.org/o/man/fa ... .html#sync .
smeezekitty
Too much latency with the software playthrough. There should be very little or no music so it isn't a big deal.Yes you could. In Audacity, Transport > Software Playthrough (on/off). This will play the recording through your computer playback device.
In any case it turns out my USB mic only supports 16KHz, 32KHz and 48 KHz. I will try recording at 32 or 48 KHz to see if it helps but the intermittent nature of the problem makes troubleshooting difficult.
I must say the support here is very good here. Some other software teams are akin to talking to a brick wall.
- Quality Assurance
You can buy a small doubler adaptor for the headphones out of the radio that would still let you record into computer line-in (if you have one).
Recording a radio acoustically is very sub-optimal.
