Audacity 2.0.5 compilation fails on Debian Squeeze
Please state:
GMaq
Post by GMaq » Mon Nov 11, 2013 4:13 pm
Hi,
First of all props and Kudos to the developers of Audacity, it is an indispensible tool for Linux Audio enthusiasts!
I am the maintainer of AV Linux and regularly compile/package Audacity, AV Linux is currently based on Debian 6.0 (Squeeze). I have had no difficulty compiling and providing packages for previous versions up to 2.0.3 however compilation on 2.0.5 fails with this:
Code: Select all
export/ExportPCM.cpp: In member function ‘bool ExportPCM::AddStrings(AudacityProject*, SNDFILE*, Tags*, int)’:
export/ExportPCM.cpp:740:28: error: ‘SF_STR_GENRE’ was not declared in this scope
export/ExportPCM.cpp:764:28: error: ‘SF_STR_TRACKNUMBER’ was not declared in this scope
make[1]: *** [export/ExportPCM.o] Error 1
make[1]: Leaving directory `/home/glen/Packaging/AUDACITY/audacity-src-2.0.5/src'
make: *** [audacity] Error 2
My guess is it may be related to Debian Squeeze using GTK 2.20 and Audacity's code looking for features of GTK 2.24+ but that is just a guess. Please note that the ./configure stage succeeds with no reported errors or missing dependencies.
I am using this to configure:
Code: Select all
./configure --prefix=/usr --with-libtwolame
I hope that this can be patched or fixed for AV Linux users to continue to enjoy the latest Audacity. Your time and attention are appreciated!
Glen MacArthur - AV Linux Maintainer
GMaq
[SOLVED] Re: Audacity 2.0.5 compilation fails on Debian Sque
Post by GMaq » Mon Nov 11, 2013 5:38 pm
Hi,
A little more digging and the problem had nothing to do with GTK but was related to 'libsndfile1', although Audacity specs 1.0.20, in truth it requires features from libsndfile1 1.0.25 for 2.0.5 to successfully compile.
Sorry for the noise, I would suggest updating the version in your configure script or have it automatically select the libsndfile bundled in the source if version 1.0.25 is not present though if possible.
Re: Audacity 2.0.5 compilation fails on Debian Squeeze
Post by steve » Mon Nov 11, 2013 7:30 pm
Thanks for letting us know the outcome GMaq.
The developers are hoping to release 2.0.6 before the end of the year. There is a lot of work going on updating old libraries used by Audacity and updating the configure scripts etc. It may be a good idea for you to also try building from SVN so that you can report any compatibility problems that you encounter direct to the developers.
You can contact the developers is via the audacity-devel mailing list: http://audacityteam.org/contact/lists
rulet
Post by rulet » Tue Dec 17, 2013 10:13 pm
How to compile and make a packages of Audacity 2.0.5 for Debian 7?
Post by steve » Tue Dec 17, 2013 11:05 pm
rulet wrote:How to compile and make a packages of Audacity 2.0.5 for Debian 7?
The source code for Audacity 2.0.5 is available here: http://audacity.googlecode.com/files/au ... 0.5.tar.xz (direct link).
Instructions for building Audacity from source on Debian based Linux distributions: http://wiki.audacityteam.org/wiki/Compi ... ux_Mint.29
Before you start you should ensure that your user name is a member of the "sudo" group and "audio" group.
rulet
Post by rulet » Wed Dec 18, 2013 9:44 pm
When trying to compile I've got an error:
Code: Select all
 AudacityApp.cpp -o AudacityApp.o
In file included from AudacityApp.cpp:72:0:
FFmpeg.h:356:4: error: ‘SampleFormat’ does not name a type
FFmpeg.h:585:4: error: use of enum ‘SampleFormat’ without previous declaration
FFmpeg.h:622:4: error: ‘AVFormatParameters’ has not been declared
FFmpeg.h:639:4: warning: ‘av_register_protocol_fp’ initialized and declared ‘extern’ [enabled by default]
FFmpeg.h:639:4: error: ‘URLProtocol’ was not declared in this scope
FFmpeg.h:639:4: error: ‘protocol’ was not declared in this scope
FFmpeg.h:639:4: error: ‘av_register_protocol’ declared as an ‘inline’ variable
FFmpeg.h:639:4: error: expected ‘,’ or ‘;’ before ‘{’ token
FFmpeg.h: In function ‘AVCodec* av_codec_next(AVCodec*)’:
FFmpeg.h:686:4: error: declaration of C function ‘AVCodec* av_codec_next(AVCodec*)’ conflicts with
In file included from FFmpeg.h:39:0,
/usr/include/libavcodec/avcodec.h:3372:10: error: previous declaration ‘AVCodec* av_codec_next(const AVCodec*)’ here
FFmpeg.h: At global scope:
FFmpeg.h:692:4: error: ‘AVFormatParameters’ has not been declared
FFmpeg.h:698:4: warning: ‘url_open_protocol_fp’ initialized and declared ‘extern’ [enabled by default]
FFmpeg.h:698:4: error: ‘URLContext’ was not declared in this scope
FFmpeg.h:698:4: error: ‘puc’ was not declared in this scope
FFmpeg.h:698:4: error: expected primary-expression before ‘struct’
FFmpeg.h:698:4: error: expected primary-expression before ‘const’
FFmpeg.h:698:4: error: expected primary-expression before ‘int’
FFmpeg.h:698:4: error: expression list treated as compound expression in initializer [-fpermissive]
FFmpeg.h:698:4: error: ‘url_open_protocol’ declared as an ‘inline’ variable
FFmpeg.h:698:4: error: expected ‘,’ or ‘;’ before ‘{’ token
FFmpeg.h:704:4: warning: ‘url_open_fp’ initialized and declared ‘extern’ [enabled by default]
FFmpeg.h:704:4: error: ‘URLContext’ was not declared in this scope
FFmpeg.h:704:4: error: ‘puc’ was not declared in this scope
FFmpeg.h:704:4: error: expected primary-expression before ‘const’
FFmpeg.h:704:4: error: expected primary-expression before ‘int’
FFmpeg.h:704:4: error: expression list treated as compound expression in initializer [-fpermissive]
FFmpeg.h:704:4: error: ‘url_open’ declared as an ‘inline’ variable
FFmpeg.h:704:4: error: expected ‘,’ or ‘;’ before ‘{’ token
FFmpeg.h:710:4: error: ‘URLContext’ has not been declared
FFmpeg.h:716:4: warning: ‘url_close_fp’ initialized and declared ‘extern’ [enabled by default]
FFmpeg.h:716:4: error: ‘URLContext’ was not declared in this scope
FFmpeg.h:716:4: error: ‘h’ was not declared in this scope
FFmpeg.h:716:4: error: ‘url_close’ declared as an ‘inline’ variable
FFmpeg.h:716:4: error: expected ‘,’ or ‘;’ before ‘{’ token
FFmpeg.h:872:4: error: ‘AVMetadataTag’ does not name a type
FFmpeg.h:878:4: warning: ‘av_metadata_set_fp’ initialized and declared ‘extern’ [enabled by default]
FFmpeg.h:878:4: error: ‘AVMetadata’ was not declared in this scope
FFmpeg.h:878:4: error: ‘pm’ was not declared in this scope
FFmpeg.h:878:4: error: expected primary-expression before ‘const’
FFmpeg.h:878:4: error: expression list treated as compound expression in initializer [-fpermissive]
FFmpeg.h:878:4: error: ‘av_metadata_set’ declared as an ‘inline’ variable
FFmpeg.h:878:4: error: expected ‘,’ or ‘;’ before ‘{’ token
FFmpeg.h:884:4: warning: ‘av_metadata_set2_fp’ initialized and declared ‘extern’ [enabled by default]
FFmpeg.h:884:4: error: ‘AVMetadata’ was not declared in this scope
FFmpeg.h:884:4: error: ‘pm’ was not declared in this scope
FFmpeg.h:884:4: error: expected primary-expression before ‘const’
FFmpeg.h:884:4: error: expected primary-expression before ‘int’
FFmpeg.h:884:4: error: expression list treated as compound expression in initializer [-fpermissive]
FFmpeg.h:884:4: error: ‘av_metadata_set2’ declared as an ‘inline’ variable
FFmpeg.h:884:4: error: expected ‘,’ or ‘;’ before ‘{’ token
FFmpeg.h:908:4: warning: ‘av_register_protocol2_fp’ initialized and declared ‘extern’ [enabled by default]
FFmpeg.h:908:4: error: ‘URLProtocol’ was not declared in this scope
FFmpeg.h:908:4: error: ‘protocol’ was not declared in this scope
FFmpeg.h:908:4: error: expected primary-expression before ‘int’
FFmpeg.h:908:4: error: expression list treated as compound expression in initializer [-fpermissive]
FFmpeg.h:908:4: error: ‘av_register_protocol2’ declared as an ‘inline’ variable
FFmpeg.h:908:4: error: expected ‘,’ or ‘;’ before ‘{’ token
AudacityApp.cpp:221:13: warning: ‘void wxOnAssert(const wxChar*, int, const wxChar*)’ defined but not used [-Wunused-function]
make[1]: *** [AudacityApp.o] Ошибка 1
make[1]: Leaving directory `/home/r/Desktop/11111/audacity-src-2.0.5/src'
make: *** [audacity] Ошибка 2
[email protected]:~/Desktop/11111/audacity-src-2.0.5$
Reason: code tags added
Post by steve » Wed Dec 18, 2013 10:02 pm
Audacity supports FFmpeg 0.5 through 0.8. Later versions are not currently supported.
The easiest way round the problem is to build Audacity without FFmpeg support.
Code: Select all
./configure --without-ffmpeg
make
sudo make install
rulet
Post by rulet » Thu Dec 19, 2013 9:44 pm
Whether it limit audacity functionality(without ffmpeg support)? If so, how?
...Well I compiled without errors(except the messages about missing translations on Russian of about 931 messages, if I understood right from what I read in make output) with:
Code: Select all
make
Now, how to make a deb-package(-s)?
Post by steve » Fri Dec 20, 2013 1:31 pm
rulet wrote:Now, how to make a deb-package(-s)?
That is really beyond the scope of this forum. Documentation about packaging for Debian can be found here: https://wiki.debian.org/Packaging
rulet
Post by rulet » Fri Dec 20, 2013 6:29 pm
And how about first question:
