Splitting WAV files
set_jump
Re: Splitting WAV files
Post by set_jump » Thu Dec 19, 2013 6:21 pm
Please help; I can’t spot the problem. I have successfully recorded from a cassette into Audacity. I used “Add label at selection” to mark the beginning of each song w/ the title; 11 songs in the stereo track. Selected Export Multiple in .wav format, split files based on labels, & numbering before label/track. Then, used Nero Express version 5 to burn to CD-R as audio disc (cda) at the slowest speed 4x. The disc will not play in the truck player which is > 10 years old. The player takes the disc, but displays Track 00. Disc plays in all other players & sounds great. How can I help this player "find" the songs? Am I out of luck since the truck cd player is so old?
