Cannot recognize audacity, cannot download new vn. (SOLVED)
Please state:
ziggo1
Post by ziggo1 » Sat Nov 02, 2013 6:06 pm
Hi there, I have been running 2.04 audacity the last month with no worries. But today, I did my updates & upgrades in terminal, and now my Ubuntu 13.04 system cannot find audacity.
So I tried to reinstall, but get this info:
The following packages have unmet dependencies:
audacity: Depends: audacity-data (= 2.0.5+svn20131101+r8053-0~r26~ubuntu13.04.1) but 2.0.5+svn20131102+r8079-0~r26~ubuntu13.04.1 is to be installed
Depends: libavcodec-extra-53 (>= 6:0.8.6) but 6:0.8.6ubuntu2 is to be installed
Depends: libavformat-extra-53 (>= 6:0.8.6) but 6:0.8.6ubuntu2 is to be installed
Depends: libavutil-extra-51 (>= 6:0.8.6) but 6:0.8.6ubuntu2 is to be installed
Depends: libc6 (>= 2.15) but 2.17-0ubuntu5.1 is to be installed
Depends: libgcc1 (>= 1:4.1.1) but 1:4.7.3-1ubuntu1 is to be installed
Depends: libglib2.0-0 (>= 2.12.0) but 2.36.0-1ubuntu2 is to be installed
Depends: libgtk2.0-0 (>= 2.8.0) but 2.24.17-0ubuntu2 is to be installed
Depends: libportaudio2 (>= 19+svn20101113-2~) but 19+svn20111121-1build1 is to be installed
Depends: libstdc++6 (>= 4.4.0) but 4.7.3-1ubuntu1 is to be installed
Depends: libwxbase2.8-0 (>= 2.8.12.1) but 2.8.12.1-11ubuntu4 is to be installed
Depends: libwxgtk2.8-0 (>= 2.8.12.1) but 2.8.12.1-11ubuntu4 is to be installed
Cannot re-install in terminal either, I get this:
Reading package lists... Done
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
audacity : Depends: audacity-data (= 2.0.5+svn20131101+r8053-0~r26~ubuntu13.04.1) but 2.0.5+svn20131102+r8079-0~r26~ubuntu13.04.1 is to be installed
E: Unable to correct problems, you have held broken packages.
[email protected]:~$
Love using the program, and would love to know how to fix this, thank you.
DT
Re: Cannot recognize audacity, cannot download new version
Post by steve » Sat Nov 02, 2013 6:11 pm
How did you install Audacity?
ziggo1
Post by ziggo1 » Sat Nov 02, 2013 6:51 pm
Back in August I used the Ubuntu Software Center. I tried doing so again today after the search could not find the program.
Post by steve » Sat Nov 02, 2013 9:14 pm
According to this page (http://packages.ubuntu.com/raring/audacity) the repository version of Audacity for Ubuntu 13.04 is 2.0.3-1 :?
ziggo1
Post by ziggo1 » Sat Nov 02, 2013 11:11 pm
ok, then it may have been 2.0.3.
Thing is, I cannot check the version now because I cannot open the program. It worked fine this morning, and did so for the last three months.
I have now upgraded to 13.10, and same problem. I have downloaded 2.0.3 from soundforge. Can you just direct me to a page that will give me step by step to open up the tarball and get the program working again? I'd rather have the software center do it from the gui, but this does not seem to be an option now.
dt
ziggo1
Post by ziggo1 » Sun Nov 03, 2013 12:12 am
Figured it out, had to delete audacity_data, then re-install was a breeze. All is well in the universe again, cheers.
dt
Post by steve » Sun Nov 03, 2013 1:27 pm
ziggo1 wrote:Figured it out, had to delete audacity_data, then re-install was a breeze. All is well in the universe again, cheers.
Good news :). Thanks for letting us know.
