ECHO
zzzzzzz
ECHO
Post by zzzzzzz » Tue Dec 02, 2008 5:03 pm
I ran Audacity on an Apple, perfect from the moment I plugged in. Now have an XP, always an echo if I want to overlap or just listen while recording OR just have mic on for sound check. What do I need to replace so I can actually use this program. I paid for my version, then downloaded beta. What's the point if you can't sing, talk or play an instrument at all 'cause the echo throws the time off.
Re: ECHO
Post by steve » Tue Dec 02, 2008 5:17 pm
zzzzzzz wrote:I paid for my version,
Who did you pay? Did you make a donation ?
Audacity is free software.
zzzzzzz wrote:What's the point if you can't sing, talk or play an instrument at all 'cause the echo throws the time off.
There would clearly be no point at all, but it is most likely a set up problem rather than a fault with Audacity.
Click on the "Edit" menu and select "Preferences"
Then go to the "Audio I/O" tab.
"software playthrough" should be switched OFF (not selected).
Does that fix the problem?
zzzzzzz wrote:OR just have mic on for sound check.
I don't understand what you are saying here - If you have your microphone switched on and live through your speakers, there is a very good chance that it will pick up sound from the speakers and cause problems.
Re: ECHO
Post by kozikowski » Tue Dec 02, 2008 11:13 pm
You may be complaining about the wrong thing. You're supposed to be complaining about delay between the pilot track and your voice. The fact that you're complaining about echoes means you're probably not wearing headphones.
http://www.fotosearch.com/UPC142/csc38021/
That and PC's ability to record Mix-Out by accident will drive you nuts.
Windows Control Panel
Macs won't do this.
You stopped using your Mac because? Most people get fed up with PCs and go the other way.
zzzzzzz
Re: ECHO
Post by zzzzzzz » Thu Dec 04, 2008 10:28 pm
wow not one answer. settings right, bought mic audacity & headphones in a package, used friends comp. then moved, plus found a help entry that said pc inferior always an echo w/some systems. so i found my problem u guys don't know shit :twisted:
waxcylinder
Re: ECHO
Post by waxcylinder » Fri Dec 05, 2008 10:38 am
zzzzzzz wrote:.... found a help entry that said pc inferior always an echo w/some systems.......
This is exactly what Kozikowski and Steve were telling you in their responses above.
And please do try and remain civil on this forum - there's old-folks, women and kids that hang out here too . 8-)
Re: ECHO
Post by steve » Fri Dec 05, 2008 2:26 pm
zzzzzzz wrote:so i found my problem u guys don't know shit
You come crying that you don't know how to set up your computer, and then blame us for your ignorance? How ironic.
