Vst VUMT Klanghelm
musimage
Vst VUMT Klanghelm
Post by musimage » Wed Oct 16, 2013 12:39 pm
http://cjoint.com/?CJqosZt1cgy
I want to install this plugin VST to integrate old VU meters, but it does not work. Can you modify the program to make it work.
thank you,
sincerely
Jeff
Re: Vst VUMT Klanghelm
Post by steve » Wed Oct 16, 2013 2:20 pm
Audacity does not currently support real time effects, so that plug-in will not work.
Audacity has its own meters, which are not as pretty as the ones in that plug-in but work very well: http://manual.audacityteam.org/o/man/meter_toolbar.html
