Want to use PC headphones instead of Tascam US-200 (SOLVED)
luckyvic
Post by luckyvic » Mon Oct 14, 2013 10:14 pm
I would like to the headphones output on my computer (old XP) instead of the Tascam US-200 headphones.
How do I set the speakers on Audacity so I can hear what I recorded? If I have set to Tascam US-200 then I can't hear what I recorded using the computer headphones playback.
Re: Want to use PC headphones output instead of Tascam US-20
Post by kozikowski » Mon Oct 14, 2013 10:38 pm
Audacity will play to whatever you point it to in the Preferences.
Audacity > Edit > Preferences > Devices > Playback.
luckyvic
Post by luckyvic » Wed Oct 16, 2013 3:44 am
OK, thank you for your help. Got it to work.
