Exporting multiple files cuts off the ends of my files
Almost every time I export multiple files they get cut off at the ends, just a second or so. I can't figure out why! Any ideas? Thanks!
Re: Exporting multiple files cuts off the ends of my files
Which version of Audacity do you have? (look in "Audacity Menu > About Audacity...")
