pluck
Re: pluck
Do you want a sound that goes "poink!" ? If you do, then "Pluck" is the tool for the job
"Pluck" is an example of a Nyquist plug-in for generating sounds. "Nyquist" is a programming language designed for generating and processing sound and is included in Audacity. it provides a relatively easy way for users to extend Audacity's abilities in both generating and processing sounds (and other tasks). The "Pluck" effect is a simple example of a sound generator plug-in written in the Nyquist language.
You can learn more about Nyquist programming here: http://wiki.audacityteam.org/wiki/Nyqui ... _Reference
There are many other Nyquist plug-ins available here: http://wiki.audacityteam.org/wiki/Downl ... t_Plug-ins
As well as many "unofficial" and "experimental" plug-ins available in the Nyquist section of this forum: http://forum.audacityteam.org/viewforum.php?f=42
Re: pluck
Thanks! Think I'll go poink around!
steve wrote:Do you want a sound that goes "poink!" ? If you do, then "Pluck" is the tool for the job
