waxcylinder wrote:Actually solanus it was mainly Audacity testers, QA, documenters (mainly power users) who complained about the increased clicking that was required that led to its removal as an experimental feature.
For the record, I was, and still am, very much in favour of grouping plug-ins, though I agree that the first attempt at implementing this was awkward to the point of distraction.
solanus wrote:On Linux, if the list of effects runs offscreen, it automatically creates generically named submenus that allow you to mouse over them and open them horizontally, so at least you can see the effects on screen with a simple mouseover and click instead of scroll scroll scroll scroll scroll scroll.
In one way the way it works on Windows is better than how it woks on Linux. If, say, you want to use the Vocoder effect, on Linux I have to scroll down the list and try to remember which of the numbered groups it is in. On Windows I can just type "V" and immediately the list is scrolled down to plug-ins beginning with V.
solanus wrote:even if most of the developers work exclusively on Linux,
They don't. Most of the developers work on Windows.
solanus wrote:and I expect that there are at least as many (if not more) users running Audacity on Windows.
Yes, there are
a lot more downloads for the Windows build than any other.
solanus wrote: I take issue with this statement there: Categorisation has a penalty in more difficult navigation.
That certainly was the case with the original implementation, though I agree that it does not have to be (and should not be) the case.
solanus wrote:I really wish the Audacity developers would take this seriously.
It's not a question of taking it seriously. Creating a cross-platform solution is not easy, and there are a limited number of developers with a limited amount of time.
Fortunately, some of the obstacles for achieving a good solution have now been resolved - handling the loading of VST plug-ins has been improved, as has the handling of keyboard shortcuts to effects. Achieving a good solution is not just a matter of wanting a solution, but also having the resources to develop the solution. As Audacity is a free program, its resources come primarily from the time, effort, skills and money that users donate.
