Audacity newbie having problems
This section is now closed
mrnstar2008
Post by mrnstar2008 » Sun Nov 30, 2008 7:08 am
Hi.
I'm completely new to this and am trying to edit down a 45 min wav. So far, I've successfully imported it in Audacity and saved certain sections as uaps.
The problem is that now, when I open them up and hit "play", the meter toolbar doesn't work and although the "line" moves, I hear no volume. ???
What did I do and what do I do now?
Let me know if you need any more info.
Thanks for your help.
~Dawn
Re: Audacity newbie having problems
Post by kozikowski » Sun Nov 30, 2008 7:36 am
Audacity does not save sound files. Put the AUs and AUPs back where you found them.
To get a good, clear, stand-alone sound file, you need to Export As WAV, or Export Selection...As WAV.
