I've attached a screenshot of an error message I received when I couldn't get the program into the record mode. Using the time shift tool didn't seem to help. Can anyone help. The only fix i found is a windows reboot.
Audacity 2.3
Windows 8
Thanks
Bob H
Latency
- Quality Assurance
Re: Latency
If the recording won't start, reboot is the correct solution.
