Trouble with vocoder plugin in Audacity 1.3.6
This section is now closed
tomekkr
Post by tomekkr » Fri Nov 28, 2008 5:17 pm
Hi, I recently downloaded Audacity 1.3.6 for Mac os x. I tried to use the vocoder effect by doing this:
1) Carrier audio (speaking into a mic) - Right Channel
Modulator audio - Left Channel
2) Next without highlighting any of the two, I went into Effect -> Spectral Processor -> Vocoder
3) I set the Channel processing to: 1 (Right Channel)
Ok, now however, regardless of the settings I choose, it always gives me this message: "Nyquist did not return audio".
What does this mean? How can I fix this?
Re: Trouble with vocoder plugin in Audacity 1.3.6
Post by kozikowski » Fri Nov 28, 2008 7:21 pm
Traditional Audacity filters only work after you select some audio.
tomekkr
Post by tomekkr » Fri Nov 28, 2008 10:42 pm
Even if I select either one or both, it gives me the same message...
Post by kozikowski » Sat Nov 29, 2008 12:20 am
I think you have them backwards, but you should have gotten something when you pressed the go button.
Where did you get the plugin from so I can get the same one? I need a URL.
Post by steve » Sat Nov 29, 2008 7:01 am
tomekkr wrote:Hi, I recently downloaded Audacity 1.3.6 for Mac os x. I tried to use the vocoder effect by doing this:
Did you have your right and left channels as left/right channels of a stereo track?
If you have 2 mono tracks, one selected as L and the other as R, it will give that error. To make them into a stereo track, select both tracks and use "Mix and Render".
I know this is a little awkward, but I think that you are using the Nyquist Vocoder, and Nyquist in Audacity has a limitation that it can not differentiate between different tracks, so both channels must be in the same track.
Post by kozikowski » Sat Nov 29, 2008 7:03 am
<<<Nyquist Vocoder>>>
And do you have an address for this plugin?
Post by steve » Sat Nov 29, 2008 7:34 am
kozikowski wrote:<<<Nyquist Vocoder>>>
It is shipped with Audacity 1.3.5 (possibly 1.3.6 as well, but I've just got 1.3.5 installed at the moment).
I have included it as an attachment - just unzip it into your plug-ins folder.
vocoder.ny.zip
(1.82 KiB) Downloaded 1349 times
Post by steve » Sat Nov 29, 2008 7:46 am
Post by kozikowski » Sun Nov 30, 2008 5:29 am
Thank yew.
vocalz
Post by vocalz » Sun May 31, 2009 1:46 am
Hey I want to know how to use that plug in link that is a nyquist thing..thanks
