Will not record
Help for Audacity on macOS.
pepc007
Will not record
Post by pepc007 » Mon Sep 09, 2013 3:47 pm
Using Audacity 2.0.4 on OSX 10.8.4
Installation Successful.
But after pressing record and pressing play on youtube file, no audio is recorded in Audacity.
Please help.
Re: Will not record
Post by steve » Mon Sep 09, 2013 4:30 pm
Mac computers have no built in ability to record sounds that are playing on the computer.
See here for possible workarounds: http://manual.audacityteam.org/o/man/tu ... n_mac.html
Scanner7
Re: Will not record
Post by Scanner7 » Wed Sep 11, 2013 12:50 am
I was having this problem as well. Steve's reference solved the issue for me. I thought this was strange since I had been recording using Audacity without a problem. I did notice something though. If you look in Audacity Preferences under devices you will see a more current build for the core audio interface. I don't know if this affected Audacity performance. I am back to normal and a happy camper.
