Audacity 2.0.4 still crashes
Help for Audacity on macOS.
billw58
Re: Audacity 2.0.4 still crashes
Post by billw58 » Mon Sep 09, 2013 2:11 pm
Gale Andrews wrote:
billw58 wrote:I downloaded and ran the latest weekly debug build, and got the file import error (using File > Import > Audio) on the first try. The message was:
../src/mac/carbon/textctrl.cpp(2278): assert "byteBufferLen != wxCONV_FAILED" failed in SetTXNData(): Conversion to UTF-16 unexpectedly failed
Yes that message (I think from 2.0.4-alpha) is in the bugzilla report. Did that crash for you, or just a log message?
If I choose to continue running, I get the textension crash.
Gale Andrews wrote:How about trying a debug build from early in 2.0.3 release period and seeing if that error occurs in the log even with no crash: http://www.audacity.homerow.net/index.p ... 7-04.15%2F .
That does not crash and does not throw the assert. The first thing I did was rename an audio file to include a unicode character . I then tried importing a file without unicode characters (using drag and drop), then one with unicode characters. Did the same for File > Import > Audio.
Gale Andrews wrote:Here is the build (2.0.4 without file import logging):
http://www.gaclrecords.org.uk/test-buil ... -alpha.zip
It did not crash on import.
Nor for me with the above tests.
Gale Andrews wrote:I rebuilt 2.0.3 without logging and it still crashed.
So I have 2.0.3 more or less as unstable as 2.0.4 with only partial replicability of the log problem in 2.0.4.
You see 2.0.4 as much worse, and all files are affected.
Do you get any crashes in 2.0.3 if you drag in a file with Unicode characters? Or just fewer crashes?
It would be much more useful to fix the log so that it behaved as in 2.0.3, rather than stop logging.
I see 2.0.4 as almost completely unstable when importing audio files. All audio file types I've tested are affected: AIF, WAV, MP3, OGG, FLAC. As I noted, even if the file imports there is garbage in the log.
I have not stress tested 2.0.3 (e.g. tried 100 different imports), but I have not had a crash with 2.0.3 in over a week of occasional testing, using non-unicode and unicode file names.
Agreed it would be better to fix the log but in the meantime a 2.0.4a Mac maintenance release without file import logging might be in order.
-- Bill
Post by Gale Andrews » Mon Sep 09, 2013 3:44 pm
OK and I presume the log shows that the import succeeded?
If I have time I will try to find at what time point in 2.0.4-alpha the log turned the imported file name into Chinese characters on Windows. Note that it still says the import succeeded, and there is no practical problem. On Linux, the log is also wrong - it says which libraries attempted the file import but nothing else (no "import succeeded" message).
Maybe you can find out from the Mac nightly builds site at what time point the log went wrong on Mac. This may or may not have the same cause as the Windows and Linux issue.
billw58 wrote:Agreed it would be better to fix the log but in the meantime a 2.0.4a Mac maintenance release without file import logging might be in order.
I guess it depends how many users find 2.0.4 far worse than 2.0.3 for this Mac issue. I can't tell the difference between them in usability and find it hard to reproduce the log problem.
The WDM-KS issue on Windows similarly may or may not require a "maintenance release" depending how many people fall over this.
Michael_Graubart
Post by Michael_Graubart » Mon Sep 09, 2013 7:23 pm
I'm really sorry, but I can't remember exactly. It may be that the first time 2.0.4 opened but did not load any music and the second time it crashed; or I may be wrong about that.
billw58
Post by billw58 » Mon Sep 09, 2013 7:39 pm
Gale Andrews wrote:Maybe you can find out from the Mac nightly builds site at what time point the log went wrong on Mac.
For what it's worth, the May 19 build does not crash, and the May 20 build does (for me). For any import that succeeded the log looked correct. I haven't (so far) got anything past May 20 to import successfully, so I couldn't check the log.
There were several commits on May 19, including (ironically) r12334 "Patch from Michael Chinen to fix unicode import crash due to c_str and wxLogMessage - especially on Mac. Also remove the forcing of file names to lower case for display, which can never have been correct, especially for case sensitive file systems."
-- Bill
Post by Gale Andrews » Tue Sep 10, 2013 5:16 am
I'm coming to the conclusion that was a bad patch - it was the cause of the garbage file names in the log on Windows.
Can you try this one http://gaclrecords.org.uk/test-builds/a ... -2.0.4.zip . It's HEAD with r12334 reverted, so it will write the log, but I have retained one feature of that patch which is beneficial, namely removing the forced rewrite to lower case in the log. So if your file is "BB.aiff" it will show as "BB.aiff" in the log and not "bb.aiff" as it did before r12334.
billw58
Post by billw58 » Tue Sep 10, 2013 3:23 pm
Gale Andrews wrote:Can you try this one http://gaclrecords.org.uk/test-builds/a ... -2.0.4.zip . It's HEAD with r12334 reverted, so it will write the log, but I have retained one feature of that patch which is beneficial, namely removing the forced rewrite to lower case in the log. So if your file is "BB.aiff" it will show as "BB.aiff" in the log and not "bb.aiff" as it did before r12334.
Success! That works a treat. Imported MP3, AIF, OGG and FLAC via File > Import > Audio and drag-and-drop. One of the files had an extended unicode character.
Code: Select all
11:01:02: File name is /Users/Bill/Documents/Audio/Audacity tests/52 Girls.aiff
11:01:02: Mime type is *
11:01:02: Opening with libsndfile
11:01:02: Open(/Users/Bill/Documents/Audio/Audacity tests/52 Girls.aiff) succeeded
11:01:25: File name is /Users/Bill/Documents/Audio/Audacity tests/1 Føxglove.aiff
11:01:25: Mime type is *
11:01:25: Opening with libsndfile
11:01:25: Open(/Users/Bill/Documents/Audio/Audacity tests/1 Føxglove.aiff) succeeded
11:01:53: File name is /Users/Bill/Documents/Audio/Vinyl Conversion/Allman Bros/Brothers and Sisters/Come and Go Blues.flac
11:01:53: Mime type is *
11:01:53: Opening with libflac
11:01:53: Open(/Users/Bill/Documents/Audio/Vinyl Conversion/Allman Bros/Brothers and Sisters/Come and Go Blues.flac) succeeded
11:02:36: File name is /Users/Bill/Documents/Audio/Grateful Dead/gd77-10-28/1977-10-28 - Kansas City/gd77-10-28d1t01_vbr.mp3
11:02:36: Mime type is *
11:02:36: Opening with libsndfile
11:02:36: Opening with libmad
11:02:36: Open(/Users/Bill/Documents/Audio/Grateful Dead/gd77-10-28/1977-10-28 - Kansas City/gd77-10-28d1t01_vbr.mp3) succeeded
11:02:39: File name is /Users/Bill/Documents/Audio/Grateful Dead/gd77-10-28/1977-10-28 - Kansas City/gd77-10-28d1t02_vbr.mp3
11:02:39: Mime type is *
11:02:39: Opening with libsndfile
11:02:40: Opening with libmad
11:02:40: Open(/Users/Bill/Documents/Audio/Grateful Dead/gd77-10-28/1977-10-28 - Kansas City/gd77-10-28d1t02_vbr.mp3) succeeded
11:02:45: File name is /Users/Bill/Documents/Audio/Grateful Dead/gd77-10-28/1977-10-28 - Kansas City/gd77-10-28d1t03_vbr.mp3
11:02:45: Mime type is *
11:02:45: Opening with libsndfile
11:02:45: Opening with libmad
11:02:45: Open(/Users/Bill/Documents/Audio/Grateful Dead/gd77-10-28/1977-10-28 - Kansas City/gd77-10-28d1t03_vbr.mp3) succeeded
11:02:48: File name is /Users/Bill/Documents/Audio/Grateful Dead/gd77-10-28/1977-10-28 - Kansas City/gd77-10-28d1t04_vbr.mp3
11:02:48: Mime type is *
11:02:48: Opening with libsndfile
11:02:48: Opening with libmad
11:02:48: Open(/Users/Bill/Documents/Audio/Grateful Dead/gd77-10-28/1977-10-28 - Kansas City/gd77-10-28d1t04_vbr.mp3) succeeded
11:03:08: File name is /Users/Bill/Documents/Audio/Grateful Dead/gd77-10-28/1977-10-28 - Kansas City/gd77-10-28d2t01_vbr.mp3
11:03:08: Mime type is *
11:03:08: Opening with libsndfile
11:03:08: Opening with libmad
11:03:08: Open(/Users/Bill/Documents/Audio/Grateful Dead/gd77-10-28/1977-10-28 - Kansas City/gd77-10-28d2t01_vbr.mp3) succeeded
11:03:09: File name is /Users/Bill/Documents/Audio/Grateful Dead/gd77-10-28/1977-10-28 - Kansas City/gd77-10-28d2t02_vbr.mp3
11:03:09: Mime type is *
11:03:09: Opening with libsndfile
11:03:09: Opening with libmad
11:03:09: Open(/Users/Bill/Documents/Audio/Grateful Dead/gd77-10-28/1977-10-28 - Kansas City/gd77-10-28d2t02_vbr.mp3) succeeded
11:03:14: File name is /Users/Bill/Documents/Audio/Grateful Dead/gd77-10-28/1977-10-28 - Kansas City/gd77-10-28d2t03_vbr.mp3
11:03:14: Mime type is *
11:03:14: Opening with libsndfile
11:03:14: Opening with libmad
11:03:14: Open(/Users/Bill/Documents/Audio/Grateful Dead/gd77-10-28/1977-10-28 - Kansas City/gd77-10-28d2t03_vbr.mp3) succeeded
11:03:18: File name is /Users/Bill/Documents/Audio/Grateful Dead/gd77-10-28/1977-10-28 - Kansas City/gd77-10-28d2t04_vbr.mp3
11:03:18: Mime type is *
11:03:18: Opening with libsndfile
11:03:18: Opening with libmad
11:03:18: Open(/Users/Bill/Documents/Audio/Grateful Dead/gd77-10-28/1977-10-28 - Kansas City/gd77-10-28d2t04_vbr.mp3) succeeded
2.0.3 of course showed the conversion to lower case:
Code: Select all
12:46:32: File name is /users/bill/documents/audio/grateful dead/gd77-10-28/1977-10-28 - kansas city/gd77-10-28d1t01_vbr.mp3
12:46:32: Mime type is *
12:46:32: Opening with libsndfile
12:46:32: Opening with libmad
12:46:32: Open(/users/bill/documents/audio/grateful dead/gd77-10-28/1977-10-28 - kansas city/gd77-10-28d1t01_vbr.mp3) succeeded
Where do we go from here? Hold this for 2.0.5, push out a maintenance release, or point people who complain of this bug to your custom build?
What is your experience using this build?
-- Bill
djblanch
Post by djblanch » Tue Sep 10, 2013 5:07 pm
I tried to open a file with audacity-macosx-ub-revert-r12334-2.0.4, and it crashed. I'm on a MacBook running OS 10.7.5. Here's the crash report:
Code: Select all
Process:         Audacity [43278]
Path:            /Applications/Audacity 2.0.4 ƒ/Audacity 2.0.4.app/Contents/MacOS/Audacity
Identifier:      net.sourceforge.audacity
Version:         2.0.4.0 (2.0.4.0)
Code Type:       X86 (Native)
Parent Process:  launchd [282]
Date/Time:       2013-09-09 17:26:54.664 -0700
OS Version:      Mac OS X 10.7.5 (11G63)
Report Version:  9
Interval Since Last Report:          890405 sec
Crashes Since Last Report:           21
Per-App Interval Since Last Report:  15002 sec
Per-App Crashes Since Last Report:   10
Anonymous UUID:                      367D236E-3E77-4854-8CC6-2708F0C40634
Crashed Thread:  0
Exception Type:  EXC_BAD_ACCESS (SIGBUS)
Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000001186ffe
VM Regions Near 0x1186ffe:
    MALLOC metadata        000000000117b000-0000000001186000 [   44K] rw-/rwx SM=PRV
--> MALLOC guard page      0000000001186000-0000000001187000 [    4K] ---/rwx SM=NUL
    VM_ALLOCATE            0000000001187000-000000000118c000 [   20K] rw-/rwx SM=PRV
Thread 0 Crashed:
0   ???                           	0x9cdf733b 0 + 2631889723
1   ???                           	0x9a6c91fa 0 + 2590806522
2   ???                           	0x9a6ef450 0 + 2590962768
3   ???                           	0x9a6eb1f9 0 + 2590945785
4   ???                           	0x9a6dde92 0 + 2590891666
5   ???                           	0x9a6ddc97 0 + 2590891159
6   ???                           	0x9a6ddc37 0 + 2590891063
7   ???                           	0x9a6e4546 0 + 2590917958
8   ???                           	0x9a6e4a6f 0 + 2590919279
9   ???                           	0x9a6d2456 0 + 2590843990
10  ???                           	0x9a6d47b0 0 + 2590853040
11  ???                           	0x0043cdc5 0 + 4443589
12  ???                           	0x0043ced3 0 + 4443859
13  ???                           	0x0043cab8 0 + 4442808
14  ???                           	0x004ea4b9 0 + 5153977
15  ???                           	0x005567e6 0 + 5597158
16  ???                           	0x004ecaa3 0 + 5163683
17  ???                           	0x00037a7b 0 + 227963
18  ???                           	0x00555fe1 0 + 5595105
19  ???                           	0x0055605b 0 + 5595227
20  ???                           	0x00125b7b 0 + 1203067
21  ???                           	0x00199aa5 0 + 1677989
22  ???                           	0x001511b2 0 + 1380786
23  ???                           	0x0023e1f0 0 + 2351600
24  ???                           	0x0018d3eb 0 + 1627115
25  ???                           	0x0059b0e3 0 + 5877987
26  ???                           	0x0059b25f 0 + 5878367
27  ???                           	0x0059b62f 0 + 5879343
28  ???                           	0x004bbaaf 0 + 4962991
29  ???                           	0x004201a8 0 + 4325800
30  ???                           	0x004514ef 0 + 4527343
31  ???                           	0x9a621c0c 0 + 2590120972
32  ???                           	0x9a49d313 0 + 2588529427
33  ???                           	0x9a49c790 0 + 2588526480
34  ???                           	0x9a4b1571 0 + 2588611953
35  ???                           	0x9a6220d0 0 + 2590122192
36  ???                           	0x9a62213a 0 + 2590122298
37  ???                           	0x9a68d98d 0 + 2590562701
38  ???                           	0x9a4edd79 0 + 2588859769
39  ???                           	0x9a67e88c 0 + 2590501004
40  ???                           	0x9a67e987 0 + 2590501255
41  ???                           	0x004481d0 0 + 4489680
42  ???                           	0x003e64ba 0 + 4089018
43  ???                           	0x9a621c0c 0 + 2590120972
44  ???                           	0x9a49d313 0 + 2588529427
45  ???                           	0x9a49c790 0 + 2588526480
46  ???                           	0x9a4b1571 0 + 2588611953
47  ???                           	0x9a4b1d27 0 + 2588613927
48  ???                           	0x9a49d7ce 0 + 2588530638
49  ???                           	0x9a49c790 0 + 2588526480
50  ???                           	0x9a4b1571 0 + 2588611953
51  ???                           	0x003e4056 0 + 4079702
52  ???                           	0x003e412f 0 + 4079919
53  ???                           	0x003fca53 0 + 4180563
54  ???                           	0x0048f68f 0 + 4781711
55  ???                           	0x004698d3 0 + 4626643
56  ???                           	0x0054a34a 0 + 5546826
57  ???                           	0x0003f24b 0 + 258635
58  ???                           	0x0003efae 0 + 257966
59  ???                           	0x0003eed5 0 + 257749
Thread 1:
0   ???                           	0x9be4c90a 0 + 2615462154
1   ???                           	0x9a91f853 0 + 2593257555
Thread 2:
0   ???                           	0x9be49d36 0 + 2615450934
1   ???                           	0x9cdcc439 0 + 2631713849
2   ???                           	0x00050234 0 + 328244
3   ???                           	0x9ce1eed9 0 + 2632052441
4   ???                           	0x9ce226de 0 + 2632066782
Thread 3:: com.apple.CFSocket.private
0   ???                           	0x9be4bb42 0 + 2615458626
1   ???                           	0x9ce1eed9 0 + 2632052441
2   ???                           	0x9ce226de 0 + 2632066782
Thread 4:
0   ???                           	0x9be4c02e 0 + 2615459886
1   ???                           	0x9ce226fe 0 + 2632066814
Thread 5:
Thread 6:: com.apple.appkit-heartbeat
0   ???                           	0x9be4bbb2 0 + 2615458738
1   ???                           	0x9cdd3558 0 + 2631742808
2   ???                           	0x991246da 0 + 2568111834
3   ???                           	0x9b019e25 0 + 2600574501
4   ???                           	0x9b019dd5 0 + 2600574421
5   ???                           	0x9ce1eed9 0 + 2632052441
6   ???                           	0x9ce226de 0 + 2632066782
Thread 7:
Thread 0 crashed with X86 Thread State (32-bit):
  eax: 0x00000000  ebx: 0x016285c0  ecx: 0x00000036  edx: 0xffb202c0
  edi: 0x01e4a3e0  esi: 0x01666d66  ebp: 0xbfffdc88  esp: 0xbfffdc7c
   ss: 0x00000023  efl: 0x00010286  eip: 0x9cdf733b   cs: 0x0000001b
   ds: 0x00000023   es: 0x00000023   fs: 0x00000000   gs: 0x0000000f
  cr2: 0x01186ffe
Logical CPU: 0
Binary Images:
0x8fe4f000 - 0x8fe81aa7  dyld (195.6 - ???) <60FD3471-A1D7-342E-99A7-3EDECDAEC6EC> /usr/lib/dyld
External Modification Summary:
  Calls made by other processes targeting this process:
    task_for_pid: 34
    thread_create: 0
    thread_set_state: 0
  Calls made by this process:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
  Calls made by all processes on this machine:
    task_for_pid: 15182900
    thread_create: 0
    thread_set_state: 0
Code: Select all
VM Region Summary:
ReadOnly portion of Libraries: Total=280K resident=280K(100%) swapped_out_or_unallocated=0K(0%)
Writable regions: Total=143.5M written=19.9M(14%) resident=65.9M(46%) swapped_out=3812K(3%) unallocated=77.7M(54%)
REGION TYPE                      VIRTUAL
(null) (reserved)                   208K        reserved VM address space (unallocated)
ATS (font support)                 32.9M
CG backing stores                  13.3M
CG image                            124K
CG raster data                      236K
CG shared images                   3448K
CoreGraphics                          8K
CoreServices                       2692K
MALLOC                             59.1M
MALLOC guard page                    64K
Memory tag=240                        4K
Memory tag=242                       12K
Memory tag=249                      156K
OpenCL                               28K
Stack                              66.6M
Stack (reserved)                    516K        reserved VM address space (unallocated)
VM_ALLOCATE                        22.5M
__DATA                              172K
__LINKEDIT                           76K
__TEXT                              204K
mapped file                       334.6M
shared memory                      19.1M
shared pmap                        16.4M
TOTAL                             572.3M
TOTAL, minus reserved VM space    571.6M
Model: MacBook7,1, BootROM MB71.0039.B0E, 2 processors, Intel Core 2 Duo, 2.4 GHz, 2 GB, SMC 1.60f6
Graphics: NVIDIA GeForce 320M, NVIDIA GeForce 320M, PCI, 256 MB
Memory Module: BANK 0/DIMM0, 1 GB, DDR3, 1067 MHz, 0x80AD, 0x484D54313132533654465238432D47372020
Memory Module: BANK 1/DIMM0, 1 GB, DDR3, 1067 MHz, 0x80AD, 0x484D54313132533654465238432D47372020
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x93), Broadcom BCM43xx 1.0 (5.106.198.19.22)
Bluetooth: Version 4.0.8f17, 2 service, 18 devices, 1 incoming serial ports
Network Service: Wi-Fi, AirPort, en1
Serial ATA Device: Hitachi HTS545025B9SA02, 250.06 GB
Serial ATA Device: HL-DT-ST DVDRW  GS23N
USB Device: HL-2270DW series, 0x04f9  (Brother International Corporation), 0x0042, 0x26400000 / 2
USB Device: iPad, apple_vendor_id, 0x129f, 0x24100000 / 3
USB Device: Built-in iSight, apple_vendor_id, 0x8507, 0x24600000 / 2
USB Device: BRCM2070 Hub, 0x0a5c  (Broadcom Corp.), 0x4500, 0x06600000 / 3
USB Device: Bluetooth USB Host Controller, apple_vendor_id, 0x8218, 0x06630000 / 4
USB Device: Apple Internal Keyboard / Trackpad, apple_vendor_id, 0x0236, 0x06300000 / 2
Reason: code tags added
djblanch
Post by djblanch » Tue Sep 10, 2013 5:16 pm
Then I reopened Audacity (latest build of 2.0.4), new file, added tracks, and tried to import a file (with no accents or strange characters in the name). Here's the crash report:
Code: Select all
Report Version:  9
Crashed Thread:  0
Thread 0 Crashed:
Thread 1:
Thread 2:
Thread 4:
Thread 5:
Thread 7:
  cr2: 0x01186ffe
Logical CPU: 0
Binary Images:
    task_for_pid: 34
    thread_create: 0
    thread_set_state: 0
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
    thread_create: 0
    thread_set_state: 0
Code: Select all
VM Region Summary:
REGION TYPE                      VIRTUAL
CG image                            124K
CG raster data                      236K
CoreGraphics                          8K
CoreServices                       2692K
MALLOC                             59.1M
Memory tag=240                        4K
Memory tag=242                       12K
Memory tag=249                      156K
OpenCL                               28K
Stack                              66.6M
VM_ALLOCATE                        22.5M
__DATA                              172K
__LINKEDIT                           76K
__TEXT                              204K
mapped file                       334.6M
shared memory                      19.1M
shared pmap                        16.4M
TOTAL                             572.3M
Post by Gale Andrews » Tue Sep 10, 2013 6:15 pm
billw58 wrote:Where do we go from here? Hold this for 2.0.5, push out a maintenance release, or point people who complain of this bug to your custom build?
Thanks for testing, Bill.
So far, seven users including you can import files using that patched build where they can't in 2.0.4. Three of those users were running Mac in French or German, so could not avoid Unicode characters. Also there are several users where the other build that removes import logging has the same beneficial effect.
The patched build works fine for me so far, but then so does the official 2.0.4 (at the moment). Note this is not a fix, it would just reduce the occurrences of the bug (that apparently started in 1.3.11) back to something like their 2.0.3 frequency.
I'm intending to post to the -devel thread where Richard approved Michael's fix asking to reconsider that fix. Before I do that, I need to test my patch on Linux. If anyone else wants to test it, the patch is attached.
I think we're close to wanting a 2.0.4a for Mac. I've seen ten reports today and more than that the day before, so it's more common than the WDM-KS problem. If the number of new reports were to decline in the next few days, perhaps we could manage by linking to the patched build on the Forum.
revert_mb_str.patch
(1.43 KiB) Downloaded 70 times
billw58
Post by billw58 » Tue Sep 10, 2013 6:16 pm
Try getting rid of the "ƒ" character in the folder name (although that's no problem for me).
The "???"s in the crash report are troubling - it seems to have gone completely off the rails.
We'll continue working on this. Thanks for your help.
-- Bill
