Audacity 2.0.4 still crashes
Michael_Graubart
Re: Audacity 2.0.4 still crashes
Thanks, Gale, for your comprehensive reply to my last post. Previously, I had tried rebooting my computer 3 times after renaming the file I was using to experiment with (and once before renaming it), with no success. In response to your recommendation, I now tried Import/Audio and Audacity 2.0.4 crashed immediately.
I then searched around and found one audio file, an mp3, on my HD that had a German title with Umlauts on one vowel. Note that this is not the aiff file that I had been using as my test object. I removed the Umlauts from the newly-discovered mp3 and tried importing the original experimental aiff file. Lo and behold, it imported with no trouble at all. This is excellent so far as it goes, but an ambiguous result if one wants to draw conclusions from it, because the success might have been due to the removal of Umlauts (from a different file) or because it was the second time I tried the Import/Audio route.
At any rate I can now import any audio file. I can even import my experimental aiff file after inserting Umlauts into its own name. How long the success will survive remains to be seen.
Thank you again.
Thank you again.
Michael_Graubart
PS: Well, here is my answer to my own question. After submitting the above post, I shut my computer down. A little later, I started it again — and I can no longer import audio files into Audacity 2.0.4 (even though there are no longer any audio files with accents or Umlauts in their names or those of their containing folders on my HD).
I can do so without difficulty in Audacity 2.0.3, and always have been able to. So I must abandon Audacity 2.0.4 and stay with Audacity 2.0.3 until such time as this bug is fixed. How will I find out whether an update has been released?
billw58
On this page: http://audacityteam.org/ you can "Get Notified of New Version" (scroll to the bottom of the page) by entering your email address.Michael_Graubart wrote:How will I find out whether an update has been released?
-- Bill
Michael_Graubart
Thanks, Bill.
- Quality Assurance
Can you find the crash report for that specific crash ( Finder, Go > Go to Folder and type ~/Library/Logs/DiagnosticReports/ )? Or could you make the crash happen again in 2.0.4?Michael_Graubart wrote:PS: Well, here is my answer to my own question. After submitting the above post, I shut my computer down. A little later, I started it again — and I can no longer import audio files into Audacity 2.0.4 (even though there are no longer any audio files with accents or Umlauts in their names or those of their containing folders on my HD).
If you can import any files into 2.0.4 (now or later), could you choose Help > Show Log... , drag select all the text and paste it here?
I think Bill tends to find relatively little problem with 2.0.3 but I (and most people who experience this) find 2.0.3 no better.Michael_Graubart wrote:I can do so without difficulty in Audacity 2.0.3, and always have been able to. So I must abandon Audacity 2.0.4 and stay with Audacity 2.0.3 until such time as this bug is fixed.
I just imported AIFF's with Chinese names into 2.0.4 without problem, quit 2.0.4, launched 2.0.3, File > Open Recent, chose one of the "Chinese" files, which imported. Then I chose a file without Chinese characters and it crashed with the usual "textension" crash report. After that I could import nothing into 2.0.3 or 2.0.4 until I rebooted.
Bill mentioned that the unlike the Log in 2.0.3, the Log in 2.0.4 on Mac may not show that the import has succeeded and/or may show junk that looks like it comes from the file filtering code. On one occasion out of ten, I got two lines that just said "1" and no "import succeeded", otherwise I got "import succeeded". Maybe that bug depends on the file name or something else. I was able to export over the AIFF file whose import did not show "succeeded".
I should be able to make a Mac build that doesn't log imports if anyone wants to try it - I'll post it here. However at the moment I still think the log problem is separate from the textension bug and just makes it much worse on some machines. I noticed looking at Michael Graubart's 2.0.4 crash report and several 2.0.0, 2.0.2 and 2.0.3 reports that the calls in the crashed thread are completely identical.
billw58
I downloaded and ran the latest weekly debug build, and got the file import error (using File > Import > Audio) on the first try. The message was:
I'd be very happy to try a build without file import logging.
-- Bill
This is way down the thread from the "textension" calls, and as I read the thread, still within the chain that is writing to the log window. It seems that garbage is being passed from this point.../src/mac/carbon/textctrl.cpp(2278): assert "byteBufferLen != wxCONV_FAILED" failed in SetTXNData(): Conversion to UTF-16 unexpectedly failed
-- Bill
- Quality Assurance
Yes that message (I think from 2.0.4-alpha) is in the bugzilla report. Did that crash for you, or just a log message?billw58 wrote:I downloaded and ran the latest weekly debug build, and got the file import error (using File > Import > Audio) on the first try. The message was:../src/mac/carbon/textctrl.cpp(2278): assert "byteBufferLen != wxCONV_FAILED" failed in SetTXNData(): Conversion to UTF-16 unexpectedly failed
How about trying a debug build from early in 2.0.3 release period and seeing if that error occurs in the log even with no crash: http://www.audacity.homerow.net/index.p ... 7-04.15%2F .
Here is the build (2.0.4 without file import logging):
http://www.gaclrecords.org.uk/test-buil ... -alpha.zip
It did not crash on import.
I rebuilt 2.0.3 without logging and it still crashed.
So I have 2.0.3 more or less as unstable as 2.0.4 with only partial replicability of the log problem in 2.0.4.
You see 2.0.4 as much worse, and all files are affected.
Do you get any crashes in 2.0.3 if you drag in a file with Unicode characters? Or just fewer crashes?
It would be much more useful to fix the log so that it behaved as in 2.0.3, rather than stop logging.
Michael_Graubart
Gale,
Here are the last two crash reports — in two successive [osts because of their size — both with 2.0.4 after I had shut my computer down and later restarted it. I tried twice before abandoning 2.0.4. I then uninstalled and deleted 2.0.4, but if necessary I can download another copy. I am having no trouble with 2.0.3, and never have had.
Code: Select all
Process: Audacity [266]
Path: /Applications/Audacity 2.0.4/Audacity 2.0.4.app/Contents/MacOS/Audacity
Identifier: net.sourceforge.audacity
Version: 2.0.4.0 (2.0.4.0)
Code Type: X86 (Native)
Parent Process: launchd [132]
User ID: 501
Date/Time: 2013-09-08 19:57:05.336 +0100
OS Version: Mac OS X 10.8.4 (12E55)
Report Version: 10
Crashed Thread: 2 Dispatch queue: com.apple.root.default-overcommit-priority
Exception Type: EXC_BAD_INSTRUCTION (SIGILL)
Exception Codes: 0x0000000000000001, 0x0000000000000000
Application Specific Information:
objc[266]: autorelease pool page 0x398b000 corrupted
magic 0x1fe3cadc 0x1fe7e6f5 0x442644f5 0x13224201
pthread 0x200ac8e4
Thread 0:: Dispatch queue: com.apple.main-thread
0 libsystem_c.dylib 0x94bc9b4a memmove$VARIANT$sse42 + 397
1 com.apple.HIToolbox 0x93deb20b CArray::ReplaceElements(long, long, long, void const*) + 125
2 com.apple.HIToolbox 0x93e0efad CUnicodeTextension::UnicodeReplaceRange(long, long, TReplaceParams const&, unsigned char, unsigned char) + 1873
3 com.apple.HIToolbox 0x93e0f591 CUnicodeTextension::ReplaceRange(long, long, TReplaceParams const&, unsigned char, unsigned char) + 97
4 com.apple.HIToolbox 0x93e0117e CReplaceTextCommand::DoMainAction() + 74
5 com.apple.HIToolbox 0x93e00799 CTextensionEditCommand::DoIt(short*) + 25
6 com.apple.HIToolbox 0x93e0009e CTextensionCommand::Execute(short*) + 54
7 com.apple.HIToolbox 0x93e08387 OpaqueTXNObject::ExecuteCurrCommand() + 121
8 com.apple.HIToolbox 0x93e038a5 OpaqueTXNObject::NewCommand(short, AttrObjModifier const*, TKeyDownParams*, TReplaceParams*) + 1065
9 com.apple.HIToolbox 0x93df9502 DoSetDataCommand(OpaqueTXNObject*, unsigned long, unsigned long, TReplaceParams*) + 314
10 com.apple.HIToolbox 0x93df8ecd TXNSetData + 1037
11 net.sourceforge.audacity 0x0043cdc5 wxMacMLTEControl::SetTXNData(wxString const&, unsigned long, unsigned long) + 165
12 net.sourceforge.audacity 0x0043ced3 wxMacMLTEControl::WriteText(wxString const&) + 195
13 net.sourceforge.audacity 0x0043cab8 wxTextCtrl::WriteText(wxString const&) + 168
14 net.sourceforge.audacity 0x004ea4b9 wxLogWindow::DoLogString(wchar_t const*, long) + 137
15 net.sourceforge.audacity 0x005567e6 wxLog::DoLog(unsigned long, wchar_t const*, long) + 342
16 net.sourceforge.audacity 0x004ecaa3 wxLogWindow::DoLog(unsigned long, wchar_t const*, long) + 99
17 net.sourceforge.audacity 0x00037a7b wxLog::OnLog(unsigned long, wchar_t const*, long) + 235
18 net.sourceforge.audacity 0x00555fe1 wxVLogMessage(wchar_t const*, char*) + 113
19 net.sourceforge.audacity 0x0055605b wxLogMessage(wchar_t const*, ...) + 27
20 net.sourceforge.audacity 0x00125f02 Importer::Import(wxString, TrackFactory*, Track***, Tags*, wxString&) + 1794
21 net.sourceforge.audacity 0x00199aa5 AudacityProject::Import(wxString, WaveTrackArray*) + 149
22 net.sourceforge.audacity 0x001511b2 AudacityProject::OnImport() + 754
23 net.sourceforge.audacity 0x0023e1f0 CommandManager::HandleMenuID(int, unsigned int, unsigned int) + 128
24 net.sourceforge.audacity 0x0018d3eb AudacityProject::OnMenu(wxCommandEvent&) + 59
25 net.sourceforge.audacity 0x0059b0e3 wxEvtHandler::ProcessEventIfMatches(wxEventTableEntryBase const&, wxEvtHandler*, wxEvent&) + 115
26 net.sourceforge.audacity 0x0059b25f wxEventHashTable::HandleEvent(wxEvent&, wxEvtHandler*) + 111
27 net.sourceforge.audacity 0x0059b62f wxEvtHandler::ProcessEvent(wxEvent&) + 207
28 net.sourceforge.audacity 0x004bbaaf wxMenuBase::SendEvent(int, int) + 255
29 net.sourceforge.audacity 0x004201a8 wxMenu::MacHandleCommandProcess(wxMenuItem*, int, wxWindow*) + 72
30 net.sourceforge.audacity 0x004514ef wxMacWindowEventHandler(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 511
31 com.apple.HIToolbox 0x93d519bb _InvokeEventHandlerUPP(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*, long (*)(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*)) + 36
32 com.apple.HIToolbox 0x93bd9394 DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1343
33 com.apple.HIToolbox 0x93bd8780 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 430
34 com.apple.HIToolbox 0x93bec655 SendEventToEventTarget + 88
35 com.apple.HIToolbox 0x93d5186a SendHICommandEvent(unsigned long, HICommand const*, unsigned long, unsigned long, unsigned char, void const*, OpaqueEventTargetRef*, OpaqueEventTargetRef*, OpaqueEventRef**) + 498
36 com.apple.HIToolbox 0x93bc8984 SendMenuCommandWithContextAndModifiers + 70
37 com.apple.HIToolbox 0x93bc8931 SendMenuItemSelectedEvent + 268
38 com.apple.HIToolbox 0x93bc87b6 FinishMenuSelection(SelectionData*, MenuResult*, MenuResult*) + 134
39 com.apple.HIToolbox 0x93d9de7e MenuSelectCore(MenuData*, Point, double, unsigned long, OpaqueMenuRef**, unsigned short*) + 623
40 com.apple.HIToolbox 0x93d9edc6 MenuSelect + 171
41 net.sourceforge.audacity 0x004481d0 wxMacTopLevelMouseEventHandler(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 1008
42 net.sourceforge.audacity 0x003e64ba wxMacAppEventHandler(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 1114
43 com.apple.HIToolbox 0x93d519bb _InvokeEventHandlerUPP(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*, long (*)(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*)) + 36
44 com.apple.HIToolbox 0x93bd9394 DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1343
45 com.apple.HIToolbox 0x93bd8780 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 430
46 com.apple.HIToolbox 0x93bec655 SendEventToEventTarget + 88
47 com.apple.HIToolbox 0x93c0c5f6 ToolboxEventDispatcherHandler(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 2188
48 com.apple.HIToolbox 0x93bd983f DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 2538
49 com.apple.HIToolbox 0x93bd8780 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 430
50 com.apple.HIToolbox 0x93bec655 SendEventToEventTarget + 88
51 net.sourceforge.audacity 0x003e4056 wxApp::MacHandleOneEvent(void*) + 38
52 net.sourceforge.audacity 0x003e412f wxApp::MacDoOneEvent() + 127
53 net.sourceforge.audacity 0x003fca53 wxEventLoop::Dispatch() + 35
54 net.sourceforge.audacity 0x0048f68f wxEventLoopManual::Run() + 111
55 net.sourceforge.audacity 0x004698d3 wxAppBase::MainLoop() + 83
56 net.sourceforge.audacity 0x0054a34a wxEntry(int&, wchar_t**) + 154
57 net.sourceforge.audacity 0x0003f24b main + 91
58 net.sourceforge.audacity 0x0003efae _start + 216
59 net.sourceforge.audacity 0x0003eed5 start + 41
Thread 1:: Dispatch queue: com.apple.libdispatch-manager
0 libsystem_kernel.dylib 0x95f4c9ae kevent + 10
1 libdispatch.dylib 0x9527cc71 _dispatch_mgr_invoke + 993
2 libdispatch.dylib 0x9527c7a9 _dispatch_mgr_thread + 53
Thread 2 Crashed:: Dispatch queue: com.apple.root.default-overcommit-priority
0 libobjc.A.dylib 0x982a81f2 _objc_trap() + 0
1 libobjc.A.dylib 0x9829e96e objc_autoreleasePoolPush + 113
2 com.apple.CoreFoundation 0x990ac0a7 _CFAutoreleasePoolPush + 23
3 libdispatch.dylib 0x9527ae3a _dispatch_worker_thread2 + 85
4 libsystem_c.dylib 0x94be0e72 _pthread_wqthread + 441
5 libsystem_c.dylib 0x94bc8d2a start_wqthread + 30
Thread 3:
0 libsystem_kernel.dylib 0x95f498e6 mach_wait_until + 10
1 libsystem_c.dylib 0x94c6fc10 nanosleep + 375
2 net.sourceforge.audacity 0x00050234 AudioThread::Entry() + 100
3 libsystem_c.dylib 0x94bde5b7 _pthread_start + 344
4 libsystem_c.dylib 0x94bc8d4e thread_start + 34
Thread 4:
0 libsystem_kernel.dylib 0x95f4c0ee __workq_kernreturn + 10
1 libsystem_c.dylib 0x94be10ac _pthread_workq_return + 45
2 libsystem_c.dylib 0x94be0e79 _pthread_wqthread + 448
3 libsystem_c.dylib 0x94bc8d2a start_wqthread + 30
Thread 5:
Thread 6:
Thread 7:
Thread 8:: com.apple.appkit-heartbeat
0 libsystem_kernel.dylib 0x95f4bc72 __semwait_signal + 10
1 libsystem_c.dylib 0x94c68a55 nanosleep$UNIX2003 + 189
2 libsystem_c.dylib 0x94c6891e usleep$UNIX2003 + 60
3 com.apple.AppKit 0x98805c2d -[NSUIHeartBeat _heartBeatThread:] + 879
4 com.apple.Foundation 0x938d2448 -[NSThread main] + 45
5 com.apple.Foundation 0x938d23cb __NSThread__main__ + 1396
6 libsystem_c.dylib 0x94bde5b7 _pthread_start + 344
7 libsystem_c.dylib 0x94bc8d4e thread_start + 34
Thread 9:: com.apple.CoreAnimation.render-server
0 libsystem_kernel.dylib 0x95f497d2 mach_msg_trap + 10
1 libsystem_kernel.dylib 0x95f48cb0 mach_msg + 68
2 com.apple.QuartzCore 0x915eec08 CA::Render::Server::server_thread(void*) + 441
3 com.apple.QuartzCore 0x9167f816 thread_fun + 29
4 libsystem_c.dylib 0x94bde5b7 _pthread_start + 344
5 libsystem_c.dylib 0x94bc8d4e thread_start + 34
Thread 10:: CVDisplayLink
0 libsystem_kernel.dylib 0x95f4b8e2 __psynch_cvwait + 10
1 libsystem_c.dylib 0x94be32e9 _pthread_cond_wait + 938
2 libsystem_c.dylib 0x94be3572 pthread_cond_timedwait_relative_np + 47
3 com.apple.CoreVideo 0x94cc4fd7 CVDisplayLink::waitUntil(unsigned long long) + 297
4 com.apple.CoreVideo 0x94cc405c CVDisplayLink::runIOThread() + 658
5 com.apple.CoreVideo 0x94cc3db2 startIOThread(void*) + 160
Thread 2 crashed with X86 Thread State (32-bit):
eax: 0x00000000 ebx: 0x13224201 ecx: 0xb0206e94 edx: 0x00000100
edi: 0x200ac8e4 esi: 0x982a8241 ebp: 0xb0206f08 esp: 0xb0206edc
ss: 0x00000023 efl: 0x00010286 eip: 0x982a81f2 cs: 0x0000001b
ds: 0x00000023 es: 0x00000023 fs: 0x00000023 gs: 0x0000000f
cr2: 0x07581000
Logical CPU: 0
Binary Images:
0x1000 - 0xab4ffb +net.sourceforge.audacity (2.0.4.0 - 2.0.4.0) <FB28C2AD-97AB-6771-96F9-9216E4B3D108> /Applications/Audacity 2.0.4/Audacity 2.0.4.app/Contents/MacOS/Audacity
0x10a7000 - 0x11c6ffb com.apple.WebKit (8536 - 8536.30.1) <4A5E9136-681F-3AB1-AD69-B59F2B9126E7> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
0x1277000 - 0x12bfffb com.apple.audio.midi.CoreMIDI (1.9 - 78) <7AAE4076-36FA-37C1-9EAE-344F1C8F14D9> /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
0x12e4000 - 0x1f79ff3 com.apple.WebCore (8536 - 8536.30.2) <D644997F-5F1A-34B4-AF32-DD427E9043E2> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/WebCore
0x26fe000 - 0x2714ffc libexpat.1.dylib (12) <D4F1FD2B-F75A-322C-843E-113EF5F8EEAF> /usr/lib/libexpat.1.dylib
0x2796000 - 0x2797ffd com.apple.textencoding.unicode (2.5 - 2.5) <4E2ABBEB-1F0D-3C06-BA0C-C3CEDDF17BD2> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
0x27b2000 - 0x27b6fff com.apple.CommonCocoaPanels (4.0 - 16) <7676B15F-69E2-39D2-9F35-9D2959A99079> /System/Library/CoreServices/CommonCocoaPanels.bundle/Contents/MacOS/CommonCocoaPanels
0x2b00000 - 0x2bbeff3 ColorSyncDeprecated.dylib (400) <35E3054C-5DF1-30D4-A368-C4FDB0992373> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/Resources/ColorSyncDeprecated.dylib
0x2c17000 - 0x2c17ff5 +cl_kernels (???) <92FA41F0-F052-44E1-B11D-69F0822734CF> cl_kernels
0x2ca1000 - 0x2caeff3 com.apple.Librarian (1.1 - 1) <68F8F983-5F16-3BA5-BDA7-1A5451CC02BB> /System/Library/PrivateFrameworks/Librarian.framework/Versions/A/Librarian
0x2cf4000 - 0x2cf9fff com.apple.audio.AppleHDAHALPlugIn (2.3.7 - 2.3.7fc4) <903097A8-3922-3BF8-8B82-8BD1D831F6E7> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn
0x2f9b000 - 0x2f9cffd com.apple.ironwoodcore (1.1.1 - 1.1.1) <098CE576-3239-3B41-9141-A5BE6E476C84> /System/Library/PrivateFrameworks/SpeechObjects.framework/Versions/A/Frameworks/DictationServicesCore.framework/DictationServicesCore
0x2fa2000 - 0x2faaffd libcldcpuengine.dylib (2.2.16) <43E630D7-14C3-3455-9A4E-B5EBFA638C9D> /System/Library/Frameworks/OpenCL.framework/Libraries/libcldcpuengine.dylib
0x2fb8000 - 0x2fb8ff7 +hard_limiter_1413.so (???) <DF93382E-6CFD-32EE-5FBA-1F428F821839> /Applications/Audacity 2.0.4/*/hard_limiter_1413.so
0x2fbc000 - 0x2fbeff7 +sc4_1882.so (???) <8EA4B893-DD1B-CFAB-42B4-65C3695A7869> /Applications/Audacity 2.0.4/*/sc4_1882.so
0x4405000 - 0x4406ff1 +cl_kernels (???) <BBE5920B-2FB4-45E4-8CC9-E230FE946D20> cl_kernels
0x4413000 - 0x4413fff +cl_kernels (???) <6D1C9ECA-F152-4F20-BF1B-FA2F71B5818B> cl_kernels
0x441e000 - 0x441fff5 +cl_kernels (???) <B3D5C9F6-FF01-4109-9358-905AD23E1E7E> cl_kernels
0x4421000 - 0x4433fd8 +com.smartelectronix.magnus.Ambience (1.0.4 - 1.0.4) /Library/Audio/Plug-Ins/Components/Ambience.component/Contents/MacOS/Ambience
0x474d000 - 0x47bffff +com.DivXInc.DivXDecoder (6.4.0 - 6.4.0) /Library/QuickTime/DivX Decoder.component/Contents/MacOS/DivX Decoder
0xa079000 - 0xa07dfff com.apple.IOAccelerator (74.5.1 - 74.5.1) <CB7CDE62-DAEC-35AF-8ADB-3271AA2DF921> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
0xa084000 - 0xa08efff libGPUSupportMercury.dylib (8.9.2) <302EC167-66A3-3E12-8416-F03F50CA96D9> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupportMercury.dylib
0xa195000 - 0xa1b9fff com.apple.security.csparser (3.0 - 55179.13) <3CB62C6D-EFDC-34AB-B3FA-59CCCF7832D3> /System/Library/Frameworks/Security.framework/PlugIns/csparser.bundle/Contents/MacOS/csparser
0xa1c0000 - 0xa1ebff7 GLRendererFloat (8.9.2) <96FF25EA-1BC3-3FBA-85B6-08CC9F1D2077> /System/Library/Frameworks/OpenGL.framework/Resources/GLRendererFloat.bundle/GLRendererFloat
0xc29e000 - 0xc330fff unorm8_bgra.dylib (2.2.16) <1298D118-0B14-3F3D-B2CA-348A1C67183E> /System/Library/Frameworks/OpenCL.framework/Libraries/ImageFormats/unorm8_bgra.dylib
0xc342000 - 0xc3c2fff com.apple.iLifeMediaBrowser (2.7.4 - 546.7) <130581CE-0699-3524-B487-726353FDDF96> /System/Library/PrivateFrameworks/iLifeMediaBrowser.framework/Versions/A/iLifeMediaBrowser
0xd839000 - 0xd9cdffa GLEngine (8.9.2) <73F967E8-16C2-3FB2-8C04-293EB038952D> /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine
0xda04000 - 0xdb85fff libGLProgrammability.dylib (8.9.2) <B7AFCCD1-7FA5-3071-9F11-5161FFA2076C> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
0xe800000 - 0xec4dff3 com.apple.driver.AppleIntelHD4000GraphicsGLDriver (8.12.47 - 8.1.2) <5B46A344-20F2-3C75-9D42-D13092E6BB81> /System/Library/Extensions/AppleIntelHD4000GraphicsGLDriver.bundle/Contents/MacOS/AppleIntelHD4000GraphicsGLDriver
0x70000000 - 0x7015eff7 com.apple.audio.units.Components (1.9 - 1.9) <F2B2712A-3203-3875-B1FF-768E92AE0D42> /System/Library/Components/CoreAudio.component/Contents/MacOS/CoreAudio
0x8fe03000 - 0x8fe35e57 dyld (210.2.3) <4D38DEED-9837-3202-B8E9-41272D01EA2C> /usr/lib/dyld
0x90007000 - 0x90010fff com.apple.CommerceCore (1.0 - 26.1) <8C28115C-6EC1-316D-9237-F4FBCBB778C5> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCore.framework/Versions/A/CommerceCore
0x90011000 - 0x9004cfef libGLImage.dylib (8.9.2) <9D41F71E-E927-3767-A856-55480E20E9D9> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x9004d000 - 0x90169ffb com.apple.desktopservices (1.7.4 - 1.7.4) <782D711D-7930-324A-9015-686C2F86DBA3> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x9016a000 - 0x90170fff com.apple.print.framework.Print (8.0 - 258) <12AEAD24-6924-3923-9E4A-C5D21231E639> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x90171000 - 0x903edff7 com.apple.QuickTime (7.7.1 - 2599.31) <3839E1F3-7948-3E68-9AE1-A0CEE8C59212> /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
0x90b8a000 - 0x90bccff7 libcups.2.dylib (327.6) <D994A44F-CCDD-3D40-B732-79CB88F45908> /usr/lib/libcups.2.dylib
0x90bcd000 - 0x90becff3 com.apple.Ubiquity (1.2 - 243.15) <E10A2937-D671-3D14-AF8D-BA25E601F458> /System/Library/PrivateFrameworks/Ubiquity.framework/Versions/A/Ubiquity
0x90bed000 - 0x90cf8ff7 libJP2.dylib (850) <3FFCEFA6-317A-34AF-8D99-AEBB017543C5> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x90cf9000 - 0x90cfdfff com.apple.IOSurface (86.0.4 - 86.0.4) <6431ACB6-561B-314F-9A2A-FAC1578FCC86> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x90d65000 - 0x90d71ffe libkxld.dylib (2050.24.15) <BEC097B0-9D9A-3484-99DB-0F537E71963E> /usr/lib/system/libkxld.dylib
0x90d72000 - 0x90da5fff libssl.0.9.8.dylib (47.1) <1725A506-BD80-39D5-8EE8-78D2FBBE194C> /usr/lib/libssl.0.9.8.dylib
0x90da6000 - 0x90df6ff7 com.apple.CoreMediaIO (308.0 - 4155.4) <E2FF59A9-3728-3D17-A1AD-84DC1BDA2146> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
0x91079000 - 0x91496fff FaceCoreLight (2.4.1) <B12C8721-EFB3-30A2-9A1B-ABCDF5670764> /System/Library/PrivateFrameworks/FaceCoreLight.framework/Versions/A/FaceCoreLight
0x91497000 - 0x914f2fff com.apple.htmlrendering (77 - 1.1.4) <5C0C669F-AE07-3983-B38F-EB829B5CE609> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering
0x914f3000 - 0x91513ffd com.apple.ChunkingLibrary (2.0 - 133.3) <FA45EAE8-BB10-3AEE-9FDC-C0C3A533FF48> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
0x91514000 - 0x91524ff2 com.apple.LangAnalysis (1.7.0 - 1.7.0) <875363E7-6D02-3229-A9DD-E5A5568A7D61> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x91525000 - 0x9169dff5 com.apple.QuartzCore (1.8 - 304.3) <F2EFC117-CDC6-3252-A4A8-880965764385> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x9169e000 - 0x916c7fff libxslt.1.dylib (11.3) <0DE17DAA-66FF-3195-AADB-347BEB5E2EFA> /usr/lib/libxslt.1.dylib
0x919b5000 - 0x91a0ffff com.apple.Symbolication (1.3 - 93) <2C7B4F90-8834-3BCB-81BF-001B31452FB6> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
0x91a10000 - 0x91a6bff7 com.apple.AppleVAFramework (5.0.19 - 5.0.19) <3C43A555-0A22-3D7C-A3FB-CFADDDA43E9B> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
0x91a6c000 - 0x91aaefff libcurl.4.dylib (69.2) <8CC566A0-0B25-37E8-A6EC-30074C3CDB8C> /usr/lib/libcurl.4.dylib
0x91aaf000 - 0x91d6fff3 com.apple.security (7.0 - 55179.13) <000FD8E9-D070-326A-B386-51314360FD5C> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x91d70000 - 0x91dd2fff libc++.1.dylib (65.1) <C0CFF9FF-5D52-3EAE-B921-6AE1DA00A135> /usr/lib/libc++.1.dylib
0x91de2000 - 0x91dedfff libcommonCrypto.dylib (60027) <8EE30FA5-AA8D-3FA6-AB0F-05DA8B0425D9> /usr/lib/system/libcommonCrypto.dylib
0x91dee000 - 0x91deefff com.apple.Carbon (154 - 155) <17F1B675-E054-3D2C-900B-C9CE69F1FC31> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x91def000 - 0x921a7ffa libLAPACK.dylib (1073.4) <9A6E5EAD-F2F2-3D5C-B655-2B536DB477F2> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x921a8000 - 0x92834ff3 com.apple.CoreAUC (6.16.13 - 6.16.13) <3DCF4456-AF8D-3E87-B00C-C56055AF9B8E> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
0x92835000 - 0x928d2ff7 com.apple.PDFKit (2.8.4 - 2.8.4) <639CF802-BE94-39C5-AC97-B5B42FF910C2> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versions/A/PDFKit
0x928d3000 - 0x92937ff3 libstdc++.6.dylib (56) <F8FA490A-8F3C-3645-ABF5-78926CE9C62C> /usr/lib/libstdc++.6.dylib
0x92938000 - 0x9293cff7 libmacho.dylib (829) <5280A013-4F74-3F74-BE0C-7F612C49F1DC> /usr/lib/system/libmacho.dylib
0x929df000 - 0x929e8ff9 com.apple.CommonAuth (3.0 - 2.0) <34C4768C-EF8D-3DBA-AFB7-09148C8672DB> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
0x929e9000 - 0x929e9ffd libOpenScriptingUtil.dylib (148.3) <87895E27-88E2-3249-8D0E-B17E76FB00C1> /usr/lib/libOpenScriptingUtil.dylib
0x929ea000 - 0x929eafff com.apple.quartzframework (1.5 - 1.5) <9018BE5B-4070-320E-8091-6584CC17F798> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
0x929f5000 - 0x929f7ffb libRadiance.dylib (850) <83434287-A09E-3A3F-A1AC-085B563BA46D> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x929f8000 - 0x92aa2fff com.apple.LaunchServices (539.9 - 539.9) <C0E0CFFF-3714-3467-87DA-4A6F0AF1953B> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x92aa3000 - 0x937dbff7 com.apple.QuickTimeComponents.component (7.7.1 - 2599.31) <A0445D02-A1C1-3D40-8219-D8EA6B28811C> /System/Library/QuickTime/QuickTimeComponents.component/Contents/MacOS/QuickTimeComponents
0x937dc000 - 0x93833ff7 com.apple.ScalableUserInterface (1.0 - 1) <2B5E454B-BC49-3E85-B54D-1950397C448C> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/ScalableUserInterface.framework/Versions/A/ScalableUserInterface
0x93834000 - 0x93b54ff3 com.apple.Foundation (6.8 - 945.18) <BDC56A93-45C5-3459-B307-65A1CCE702C5> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x93b55000 - 0x93ba4ff6 libTIFF.dylib (850) <78E121A6-92A2-3120-883C-7AA3C2966F9C> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x93ba5000 - 0x93f88fff com.apple.HIToolbox (2.0 - 626.1) <ECC3F04F-C4B7-35BF-B10E-183B749DAB92> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x93f89000 - 0x93f8cff9 libCGXType.A.dylib (332) <07B59FCC-6229-37C2-9870-70A18E2C5598> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dylib
0x93f8d000 - 0x93f91ffc libGIF.dylib (850) <45CD8B8F-7324-3187-B01C-8E16C04F33FA> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x93f92000 - 0x93f93fff libsystem_sandbox.dylib (220.3) <C532F6A6-7E85-38F3-8660-EC1066DF67BE> /usr/lib/system/libsystem_sandbox.dylib
0x93f94000 - 0x93fb9ff7 com.apple.quartzfilters (1.8.0 - 1.7.0) <F6A88D89-AB4A-3217-9D65-C2C259B5F09B> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework/Versions/A/QuartzFilters
0x93ff7000 - 0x94045ff3 com.apple.SystemConfiguration (1.12.2 - 1.12.2) <15B4EFFC-22D1-3517-BE8C-7947DAA24729> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x94048000 - 0x94145ff7 com.apple.DiskImagesFramework (10.8.3 - 345) <B2CBC585-D206-3155-BB33-4359271AC444> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
0x94146000 - 0x9418eff5 com.apple.opencl (2.2.19 - 2.2.19) <968DD067-49D0-3B71-A96B-B3579698D992> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x9418f000 - 0x94318ff7 com.apple.vImage (6.0 - 6.0) <1D1F67FE-4F75-3689-BEF6-4A46C8039E70> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x94319000 - 0x9431afff libdnsinfo.dylib (453.19) <3B523729-84A8-3D0B-B58C-3FC185060E67> /usr/lib/system/libdnsinfo.dylib
0x9431b000 - 0x944d7ffd libicucore.A.dylib (491.11.3) <FF55E176-7D66-3DBB-AF86-84744C47A02C> /usr/lib/libicucore.A.dylib
0x944db000 - 0x948d7feb com.apple.VideoToolbox (1.0 - 926.104) <4275B89E-F826-3F65-ACE1-89052A9CAC6B> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
0x948d8000 - 0x948dafff libdyld.dylib (210.2.3) <05D6FF2A-F09B-309D-95F7-7AF10259C707> /usr/lib/system/libdyld.dylib
0x948db000 - 0x948fffff libJPEG.dylib (850) <36FEAB05-86C5-33B9-9DE9-5FAD8AEBA15F> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x94900000 - 0x94937ffa com.apple.LDAPFramework (2.4.28 - 194.5) <23668AB5-68EA-37D2-978E-C9EF22BF8C0C> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
0x94938000 - 0x9493bffc libCoreVMClient.dylib (32.3) <35B63A60-DF0A-3FB3-ABB8-164B246A43CC> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x9493c000 - 0x9494cff7 libsasl2.2.dylib (166) <D9080BA2-A365-351E-9FF2-7E0D4E8B1339> /usr/lib/libsasl2.2.dylib
0x9494d000 - 0x94997ff7 com.apple.framework.CoreWLAN (3.3 - 330.15) <74C4B50F-7016-341F-8261-D379B8F0CC97> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
0x94998000 - 0x94ae6ff3 com.apple.CFNetwork (596.4.3 - 596.4.3) <547BD138-E902-35F0-B6EC-41DD06794B22> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x94ae7000 - 0x94b41ff3 com.apple.ImageCaptureCore (5.0.4 - 5.0.4) <6313E06F-37FD-3606-BF2F-87D8598A9983> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
0x94b42000 - 0x94b51fff libGL.dylib (8.9.2) <1082B9A5-9AA3-35D4-968B-3A3FE15B1ED7> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x94b52000 - 0x94b6fff7 libresolv.9.dylib (51) <B9742A2A-DF15-3F6E-8FCE-778A58214B3A> /usr/lib/libresolv.9.dylib
0x94b76000 - 0x94b82ff8 libbz2.1.0.dylib (29) <7031A4C0-784A-3EAA-93DF-EA1F26CC9264> /usr/lib/libbz2.1.0.dylib
0x94b83000 - 0x94bc7ff7 libGLU.dylib (8.9.2) <F33F6C73-7F89-3B5B-A50F-2AB57BBA314D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x94bc8000 - 0x94c85feb libsystem_c.dylib (825.26) <6E35A83F-1A5B-3AF9-8C6D-D7B57B25FB63> /usr/lib/system/libsystem_c.dylib
0x94c86000 - 0x94c93ff7 com.apple.AppleFSCompression (49 - 1.0) <166AA1F8-E50A-3533-A3B5-8737C5118CC3> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
0x94c94000 - 0x94cbfff9 com.apple.framework.Apple80211 (8.4 - 840.22.1) <DBC31BEB-B771-315F-852D-66ADC3BD75A1> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
0x94cc0000 - 0x94cc1ffd com.apple.TrustEvaluationAgent (2.0 - 23) <E42347C0-2D3C-36A4-9200-757FFA61B388> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
0x94cc2000 - 0x94ce7ff7 com.apple.CoreVideo (1.8 - 99.4) <A26DE896-32E0-3D5E-BA89-02AD23FA96B3> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x94cf4000 - 0x94d70ff3 com.apple.Metadata (10.7.0 - 707.11) <F9BB5BBE-69D0-3309-8280-2303EB1DC455> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x94d71000 - 0x94db0ff7 com.apple.bom (12.0 - 192) <0637E52C-D151-37B3-904F-8656B2FD44DD> /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
0x94df7000 - 0x94df8fff liblangid.dylib (116) <E13CC8C5-5034-320A-A210-41A2BDE4F846> /usr/lib/liblangid.dylib
0x94df9000 - 0x94df9fff com.apple.Cocoa (6.7 - 19) <354094F0-F36B-36F9-BF5F-FD60590FBEB9> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x94dfa000 - 0x94e03fff com.apple.DiskArbitration (2.5.2 - 2.5.2) <89822A83-B450-3363-8E9C-9B80CB4450B1> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x94e34000 - 0x95276fff com.apple.CoreGraphics (1.600.0 - 332) <67E70F21-A0F1-356F-90B7-4B90C468EE2C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x95277000 - 0x95277fff com.apple.Accelerate.vecLib (3.8 - vecLib 3.8) <908B8D40-3FB5-3047-B482-3DF95025ECFC> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x95278000 - 0x9528aff7 libdispatch.dylib (228.23) <86EF7D45-2D97-3465-A449-95038AE5DABA> /usr/lib/system/libdispatch.dylib
0x9528b000 - 0x9528eff7 libcompiler_rt.dylib (30) <CE5DBDB4-0124-3E2B-9105-989DF98DD108> /usr/lib/system/libcompiler_rt.dylib
0x9528f000 - 0x9529cff7 com.apple.HelpData (2.1.4 - 85) <1E180AEF-53FF-3D8B-9513-7FCA1B25A4AB> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
0x952ce000 - 0x952d5fff liblaunch.dylib (442.26.2) <310C99F8-0811-314D-9BB9-D0ED6DFA024B> /usr/lib/system/liblaunch.dylib
0x952d6000 - 0x952ecfff com.apple.CFOpenDirectory (10.8 - 151.10) <D90DB5D4-6565-3726-B88A-21336CBE9170> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x952ed000 - 0x952fbfff libxar.1.dylib (105) <343E4A3B-1D04-34A3-94C2-8C7C9A8F736B> /usr/lib/libxar.1.dylib
0x952fc000 - 0x952fdffd libunc.dylib (25) <58599CBF-E262-3CEA-AFE1-35560E0177DC> /usr/lib/system/libunc.dylib
0x952fe000 - 0x95399fff com.apple.CoreSymbolication (3.0 - 117) <2BBBE224-301D-3931-AEF2-DD967A6E9172> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
0x9539a000 - 0x953a4fff libsystem_notify.dylib (98.5) <7EEE9475-18F8-3099-B0ED-23A3E528ABE0> /usr/lib/system/libsystem_notify.dylib
0x953a5000 - 0x953d2ffb com.apple.CoreServicesInternal (154.3 - 154.3) <A452602B-67CB-39C4-95EB-E59433C65774> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
0x953d3000 - 0x953d3fff com.apple.vecLib (3.8 - vecLib 3.8) <83160DD1-5614-3E34-80EB-97041016EF1F> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
0x953d4000 - 0x953e2fff com.apple.opengl (1.8.9 - 1.8.9) <1872D2CD-00A8-30D1-8ECC-B663F4E4C530> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x953e3000 - 0x95419ffb com.apple.DebugSymbols (98 - 98) <9A9ADA0A-E487-3C8F-9998-286EE04C235A> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
0x9541a000 - 0x9543cfff libc++abi.dylib (26) <3AAA8D55-F5F6-362B-BA3C-CCAF0D3C8E27> /usr/lib/libc++abi.dylib
0x9543d000 - 0x95444ffb libunwind.dylib (35.1) <E1E8D8B3-3C78-3AB1-B398-C180DC6DCF05> /usr/lib/system/libunwind.dylib
0x95445000 - 0x9549fffb com.apple.AE (645.6 - 645.6) <44556FF7-A869-399A-AEBB-F4E9263D9152> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x954a0000 - 0x954d1fff com.apple.DictionaryServices (1.2 - 184.4) <A31BB2CE-6965-3610-8B11-EA26EC6D7EEA> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x954d2000 - 0x95775ff3 com.apple.CoreImage (8.4.0 - 1.0.1) <C25B9EEC-4824-3088-BC08-2EA516C0728C> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/CoreImage.framework/Versions/A/CoreImage
0x957cc000 - 0x957d2ffc libCGXCoreImage.A.dylib (332) <C370B56E-888F-31E8-B6F9-C3944725FBD5> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXCoreImage.A.dylib
0x957d3000 - 0x957ecfff com.apple.Kerberos (2.0 - 1) <9BDE8F4D-DBC3-34D1-852C-898D3655A611> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x957f0000 - 0x957f3ff3 com.apple.AppleSystemInfo (2.0 - 2) <4639D755-8A68-31C9-95C4-7E7F70C233FA> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
0x957f4000 - 0x9585afff com.apple.print.framework.PrintCore (8.3 - 387.2) <0F7665F5-33F0-3661-9BE2-7DD2890E304B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x9585b000 - 0x95ac8ffb com.apple.imageKit (2.2 - 673) <CDB2AC11-6D60-34A7-83F9-F6E7DA25F97B> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Versions/A/ImageKit
0x95ac9000 - 0x95ad1fff libcopyfile.dylib (89) <4963541B-0254-371B-B29A-B6806888949B> /usr/lib/system/libcopyfile.dylib
0x95ad2000 - 0x95b2bfff com.apple.QuickLookFramework (4.0 - 555.5) <4E381B7B-7EB5-37FD-9BA7-517DB48D07A7> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
0x95b2c000 - 0x95c20ff3 com.apple.QuickLookUIFramework (4.0 - 555.5) <5A62C87F-5F74-380B-8B86-8CE3D8788603> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/Versions/A/QuickLookUI
0x95c24000 - 0x95c9fff3 com.apple.CorePDF (2.2 - 2.2) <5A52A1CF-4801-3E6C-BF6E-E5E75A8DBD8F> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
0x95d58000 - 0x95d62fff libCSync.A.dylib (332) <86C5C84F-11EC-39C0-9FAC-A93FDEEC3117> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
0x95d63000 - 0x95d66ffc libpam.2.dylib (20) <FCF74195-A99E-3B07-8E49-688D4A6F1E18> /usr/lib/libpam.2.dylib
0x95d67000 - 0x95dfffff com.apple.CoreServices.OSServices (557.6 - 557.6) <8DEEED08-A4B3-3B08-8C2A-BDDBF005B43F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x95e00000 - 0x95e15fff com.apple.ImageCapture (8.0 - 8.0) <B8BD421F-D5A9-3FB4-8E89-AD5CFC0D4030> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x95e16000 - 0x95e3bffb com.apple.framework.familycontrols (4.1 - 410) <B1755756-BEA2-3205-ADAA-68FCC32E60BD> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
0x95e3c000 - 0x95e7effb com.apple.RemoteViewServices (2.0 - 80.6) <AE962502-4539-3893-A2EB-9D384652AEAC> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
0x95e7f000 - 0x95e82fff com.apple.help (1.3.2 - 42) <AD7EB1F0-A068-3A2C-9D59-38E59CEC0D96> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x95e83000 - 0x95e96ff9 com.apple.MultitouchSupport.framework (235.29 - 235.29) <451701B6-03CE-3F26-9FF0-92D8DA1467EE> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x95e97000 - 0x95ea5ff3 libsystem_network.dylib (77.10) <7FBF5A15-97BA-3721-943E-E77F0C40DBE1> /usr/lib/system/libsystem_network.dylib
0x95ea6000 - 0x95efdff3 com.apple.HIServices (1.20 - 417) <B8410ABC-E0DB-31EB-B923-17F3B65B5F4C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x95efe000 - 0x95f0aff7 com.apple.NetAuth (4.0 - 4.0) <4983C4B8-9D95-3C4D-897E-07743326487E> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
0x95f12000 - 0x95f27fff com.apple.speech.synthesis.framework (4.1.12 - 4.1.12) <DE68CEB5-4959-3652-83B8-D2B00D3B932D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x95f2a000 - 0x95f31ff3 com.apple.NetFS (5.0 - 4.0) <1F7041F2-4E97-368C-8F5D-24153D81BBDB> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x95f32000 - 0x95f36fff com.apple.OpenDirectory (10.8 - 151.10) <B9244697-CB05-3BD3-80A7-D188B3747B03> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x95f37000 - 0x95f51ffc libsystem_kernel.dylib (2050.24.15) <9E58DCC0-D5FF-37E1-AA7F-F2206719E138> /usr/lib/system/libsystem_kernel.dylib
0x95f52000 - 0x9603bff7 libxml2.2.dylib (22.3) <015A4FA6-5BB9-3F95-AFB8-B9281E22685B> /usr/lib/libxml2.2.dylib
0x9603c000 - 0x9603cfff com.apple.ApplicationServices (45 - 45) <677C4ACC-9D12-366F-8A87-B898AC806DD9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x9603d000 - 0x9611efff libcrypto.0.9.8.dylib (47.1) <E4820342-4F42-3DEB-90DB-DE5A66C5585E> /usr/lib/libcrypto.0.9.8.dylib
0x9613f000 - 0x961f3fff com.apple.coreui (2.0 - 181.1) <C15ABF35-B7F5-34ED-A461-386DAF65D96B> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x961f4000 - 0x96327ff3 com.apple.MediaControlSender (1.7 - 170.20) <7B1AC317-AFDB-394F-8026-9561930E696B> /System/Library/PrivateFrameworks/MediaControlSender.framework/Versions/A/MediaControlSender
0x96328000 - 0x96390ff7 com.apple.framework.IOKit (2.0.1 - 755.24.1) <70DE925B-51E8-3C65-8928-FB49FD823D94> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x96391000 - 0x96696ff7 com.apple.CoreServices.CarbonCore (1037.6 - 1037.6) <4DB4B0C9-1377-3062-BE0E-CD3326ACDAF0> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x96697000 - 0x966fffe7 libvDSP.dylib (380.6) <55780308-4DCA-3B10-9703-EAFC3E13A3FA> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x96700000 - 0x96818ff7 com.apple.coreavchd (5.6.0 - 5600.4.16) <F024C78B-4FAA-38F1-A182-AD0A0A596CBE> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
0x96819000 - 0x9684cffb com.apple.GSS (3.0 - 2.0) <9566A96D-C296-3ABD-A12A-E274C81C0B25> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
0x968eb000 - 0x96932ff3 com.apple.CoreMedia (1.0 - 926.104) <D0E3BE86-12ED-31BE-816F-E72D757A9F2F> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
0x971b1000 - 0x972ecff7 libBLAS.dylib (1073.4) <FF74A147-05E1-37C4-BC10-7DEB57FE5326> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x972ed000 - 0x9735cffb com.apple.Heimdal (3.0 - 2.0) <964D9952-B0F2-34F6-8265-1823C0D5EAB8> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
0x9735d000 - 0x974baffb com.apple.QTKit (7.7.1 - 2599.31) <B9AE5675-22B0-3AA9-903F-2195DA0B04F5> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
0x974bb000 - 0x97591fff com.apple.DiscRecording (7.0 - 7000.2.4) <D201B061-9472-31CA-BC9C-E949EDC7A975> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
0x97592000 - 0x97592ffd com.apple.audio.units.AudioUnit (1.9 - 1.9) <F7638E43-F885-372E-9DAE-24D0C21AA66E> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x97593000 - 0x975d5fff libauto.dylib (185.4) <3098A75E-438E-3F18-BAAC-CD8F1CC7C2F7> /usr/lib/libauto.dylib
0x975d6000 - 0x9772fffb com.apple.audio.toolbox.AudioToolbox (1.9 - 1.9) <8BF022FC-C38A-34AA-8469-D98294094659> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x97730000 - 0x97732fff com.apple.securityhi (4.0 - 55002) <027D2D24-4043-3B43-90F3-112FB46903E8> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x97733000 - 0x97757fff com.apple.PerformanceAnalysis (1.16 - 16) <1F963AEF-27CF-3FEB-BE9C-4C15AFE56DEA> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
0x97758000 - 0x97758fff libSystem.B.dylib (169.3) <D7C4320E-C2EA-3A09-A413-D1F78382050D> /usr/lib/libSystem.B.dylib
0x97759000 - 0x97765ffa com.apple.CrashReporterSupport (10.8.3 - 418) <03BC564E-35FE-384E-87D6-6E0C55DF16E3> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
0x97766000 - 0x9776fffd com.apple.audio.SoundManager (4.0 - 4.0) <ABC5FE40-B222-36EB-9905-5C8C4BFD8C87> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound
0x97770000 - 0x9779dffe libsystem_m.dylib (3022.6) <9975D9C3-3B71-38E3-AA21-C5C5F9D9C431> /usr/lib/system/libsystem_m.dylib
0x9779e000 - 0x977ceff3 libtidy.A.dylib (15.10) <F2F4E000-E305-3089-91E6-3DB0ED07E74A> /usr/lib/libtidy.A.dylib
0x977cf000 - 0x97849ff7 com.apple.securityfoundation (6.0 - 55115.4) <69D92A90-971C-3CD3-BAB1-ADF958C568BC> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x9784a000 - 0x978aeff7 com.apple.datadetectorscore (4.1 - 269.3) <C11C2014-298E-3E2B-9F5D-02CCD3CA4AB3> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
0x978af000 - 0x978b9ffe com.apple.bsd.ServiceManagement (2.0 - 2.0) <9732BA61-D6F6-3644-82DA-FF0D6FEEFC69> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
0x978ba000 - 0x97951ff7 com.apple.ink.framework (10.8.2 - 150) <A9C3B735-7D5F-3D7D-AA70-2CC852D09CDE> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x97953000 - 0x97970fff libCRFSuite.dylib (33) <C9D72D0C-871A-39A2-8AFB-682D11AE7D0D> /usr/lib/libCRFSuite.dylib
0x9797b000 - 0x97992fff com.apple.GenerationalStorage (1.1 - 132.3) <DD0AA3DB-376D-37F3-AC5B-17AC9B9E0A63> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
0x97993000 - 0x97994fff libremovefile.dylib (23.2) <9813B2DB-2374-3AA2-99B6-AA2E9897B249> /usr/lib/system/libremovefile.dylib
0x97995000 - 0x97a93ff7 libFontParser.dylib (84.6) <7D3EB3CC-527E-3A74-816A-59CAFD2260A4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x97a94000 - 0x97ba4ffb com.apple.QuickTimeImporters.component (7.7.1 - 2599.31) <60E4B0DB-1D43-3BD5-B76C-1069C5E106CF> /System/Library/QuickTime/QuickTimeImporters.component/Contents/MacOS/QuickTimeImporters
0x97ba5000 - 0x97bc2fff libxpc.dylib (140.43) <C628073D-51A0-3541-A665-1121520508C6> /usr/lib/system/libxpc.dylib
0x97bc3000 - 0x97c55ffb libvMisc.dylib (380.6) <6DA3A03F-20BE-300D-A664-B50A7B4E4B1A> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x97c56000 - 0x97c57fff libDiagnosticMessagesClient.dylib (8) <39B3D25A-148A-3936-B800-0D393A00E64F> /usr/lib/libDiagnosticMessagesClient.dylib
0x97c58000 - 0x97ca6ffb libFontRegistry.dylib (100) <3B8350C2-4D8F-38C4-A22E-2F855D7E83D1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x97ca7000 - 0x97cc5ff3 com.apple.openscripting (1.3.6 - 148.3) <F3422C02-5ACB-343A-987B-A2D58EA2F5A8> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x97cc6000 - 0x97d27fff com.apple.audio.CoreAudio (4.1.1 - 4.1.1) <A3B911DB-77DF-3037-A47A-634B08E5727D> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x97d28000 - 0x97e20ff9 libsqlite3.dylib (138.1) <AD7C5914-35F0-37A3-9238-A29D2E26C755> /usr/lib/libsqlite3.dylib
0x97e57000 - 0x97e83ff7 libsystem_info.dylib (406.17) <AA5611DB-A944-3072-B6BE-ACAB08689547> /usr/lib/system/libsystem_info.dylib
0x97e84000 - 0x97e8bfff libsystem_dnssd.dylib (379.38.1) <4F164CA8-4A4F-3B27-B88A-0926E2FEB7D4> /usr/lib/system/libsystem_dnssd.dylib
0x97e9b000 - 0x97ea9ff7 libz.1.dylib (43) <245F1B61-2276-3BBB-9891-99934116D833> /usr/lib/libz.1.dylib
0x97eaa000 - 0x97eb1ffe com.apple.agl (3.2.1 - AGL-3.2.1) <B5A30D4D-F52B-3C3F-BA59-C22EABBDBD62> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
0x97eb2000 - 0x97ebcfff com.apple.speech.recognition.framework (4.1.5 - 4.1.5) <B855E8B4-2EE3-3BFF-8547-98A0F084F9AF> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x97ebd000 - 0x97ee6ff7 libRIP.A.dylib (332) <521E60A6-A768-3CB8-B10D-D10EECD68A94> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x97ee9000 - 0x97eedffe libcache.dylib (57) <834FDCA7-FE3B-33CC-A12A-E11E202477EC> /usr/lib/system/libcache.dylib
0x98189000 - 0x98296ff3 com.apple.ImageIO.framework (3.2.1 - 850) <C964E877-660E-3482-ACF9-EC25DFEAF307> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x98297000 - 0x983a4057 libobjc.A.dylib (532.2) <FA455371-7395-3D58-A89B-D1520612D1BC> /usr/lib/libobjc.A.dylib
0x983a5000 - 0x983ecff7 com.apple.framework.CoreWiFi (1.3 - 130.13) <1961CC70-C00D-31DE-BAB5-A077538CD5CB> /System/Library/Frameworks/CoreWiFi.framework/Versions/A/CoreWiFi
0x983ed000 - 0x983eefff libquarantine.dylib (52.1) <094A1501-373E-3397-B632-8F7C5AC8EFD5> /usr/lib/system/libquarantine.dylib
0x983ef000 - 0x9840bfff libPng.dylib (850) <26AD967A-D55E-3C5A-A643-D9953136DE58> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x9840c000 - 0x9840cfff com.apple.CoreServices (57 - 57) <956C6C6D-A5DD-314F-9C57-4A61D41F30CE> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x9840d000 - 0x984bcff7 com.apple.CoreText (260.0 - 275.16) <873ADCD9-D361-3753-A220-CDD289196AD8> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
0x984bd000 - 0x99079ff3 com.apple.AppKit (6.8 - 1187.39) <ACA24416-D910-39B8-9387-52A6C6A561F8> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x9907a000 - 0x99262ffb com.apple.CoreFoundation (6.8 - 744.19) <DDD3AA21-5B5F-3D8F-B137-AD95FCA89064> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x99263000 - 0x99275fff libbsm.0.dylib (32) <DADD385E-FE53-3458-94FB-E316A6345108> /usr/lib/libbsm.0.dylib
0x99278000 - 0x992c4fff libcorecrypto.dylib (106.2) <20EBADBA-D6D6-36F0-AE80-168E9AF13DB6> /usr/lib/system/libcorecrypto.dylib
0x992c5000 - 0x9934aff7 com.apple.SearchKit (1.4.0 - 1.4.0) <454E950F-291C-3E95-8F35-05CA0AD6B327> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x9934b000 - 0x99390ff7 com.apple.NavigationServices (3.7 - 200) <F6531764-6E43-3AF3-ACDD-8A5551EF016A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices
0x99391000 - 0x9963fffb com.apple.MediaToolbox (1.0 - 926.104) <DD264DFD-9AFB-38E2-A44C-B463DCB721A0> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
0x99640000 - 0x99899ff5 com.apple.JavaScriptCore (8536 - 8536.30) <24A2ACA7-6E51-30C6-B9AE-17A77E511735> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
0x9989a000 - 0x9996eff3 com.apple.backup.framework (1.4.3 - 1.4.3) <6EA22ED3-BA18-3A37-AE05-5D6FDA3F372F> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
0x9996f000 - 0x99b86fff com.apple.CoreData (106.1 - 407.7) <EC4B8297-8E01-3778-A8A4-E8747F91109D> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x99b87000 - 0x99c78ffc libiconv.2.dylib (34) <B096A9B7-83A6-31B3-8D2F-87D91910BF4C> /usr/lib/libiconv.2.dylib
0x99c79000 - 0x99c79fff com.apple.Accelerate (1.8 - Accelerate 1.8) <4EC0548E-3A3F-310D-A366-47B51D5B6398> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x99c7a000 - 0x99eaafff com.apple.QuartzComposer (5.1 - 284) <4E8682B7-EBAE-3C40-ABDB-8705EC7952BD> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framework/Versions/A/QuartzComposer
0x99eab000 - 0x99eabfff libsystem_blocks.dylib (59) <3A743C5D-CFA5-37D8-80A8-B6795A9DB04F> /usr/lib/system/libsystem_blocks.dylib
0x99eac000 - 0x99eecfff com.apple.MediaKit (14 - 687) <8735A76E-7766-33F5-B3D2-86630070A1BA> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
0x9a266000 - 0x9a291fff com.apple.shortcut (2.2 - 2.2) <FA94F2BF-37E1-3F16-9085-7BCCB815BAE9> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
0x9a2de000 - 0x9a37eff7 com.apple.QD (3.42.1 - 285.1) <BAAC13D2-1312-33C0-A255-FAB1D314C324> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x9a3d7000 - 0x9a3dbfff com.apple.CommonPanels (1.2.5 - 94) <6B3E7E53-7708-3DA2-8C50-59C2B4735DE1> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x9a3dc000 - 0x9a3dcfff libkeymgr.dylib (25) <D5E93F7F-9315-3AD6-92C7-941F7B54C490> /usr/lib/system/libkeymgr.dylib
0x9a3e9000 - 0x9a400ff4 com.apple.CoreMediaAuthoring (2.1 - 914) <DEB24207-C250-3308-8C97-E4FA700A8616> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versions/A/CoreMediaAuthoring
0x9a401000 - 0x9a404ff7 com.apple.TCC (1.0 - 1) <437D76CD-6437-3B55-BE2C-A53508858256> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
0x9a40a000 - 0x9a43ffff libTrueTypeScaler.dylib (84.6) <B7DB746B-7A61-38EF-8CA7-408ED9C14A02> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libTrueTypeScaler.dylib
0x9a440000 - 0x9a4b5ff7 com.apple.ApplicationServices.ATS (332 - 341.1) <BEE998BC-E4A5-3BA0-A6B5-31A1DFA1522C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x9a4b6000 - 0x9a574ff3 com.apple.ColorSync (4.8.0 - 4.8.0) <EFEDCB37-4F20-3CEC-A185-5D2976E11BAC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x9a575000 - 0x9a57bfff libGFXShared.dylib (8.9.2) <F3B0E66D-5C47-3A5A-A2CD-F0C58E8322C3> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x9a57c000 - 0x9a5f8ffb libType1Scaler.dylib (101.1) <0D94D786-29F7-33DB-B64B-B264FA5EACD2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libType1Scaler.dylib
0x9a5f9000 - 0x9a5fbffd libCVMSPluginSupport.dylib (8.9.2) <D6D0BB75-42DA-3772-AB5E-CBD59B343393> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
0x9a653000 - 0x9a65dfff com.apple.DisplayServicesFW (2.7.2 - 357) <5042CDAE-5580-3204-B675-745DA083E7AA> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 14
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 314
thread_create: 1
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=213.5M resident=125.1M(59%) swapped_out_or_unallocated=88.4M(41%)
Writable regions: Total=185.4M written=16.0M(9%) resident=49.9M(27%) swapped_out=0K(0%) unallocated=135.5M(73%)
REGION TYPE VIRTUAL
ATS (font support) 33.0M
CG backing stores 10.0M
CG image 64K
CG raster data 104K
CG shared images 1216K
CoreAnimation 1500K
CoreImage 4K
CoreServices 1652K
IOKit 27.8M
MALLOC 92.0M
MALLOC guard page 48K
Memory tag=240 4K
Memory tag=242 12K
Memory tag=249 156K
Memory tag=35 2964K
OpenCL 40K
OpenGL GLSL 1552K
OpenGL GLSL (reserved) 128K reserved VM address space (unallocated)
Stack 69.1M
VM_ALLOCATE 18.0M
__DATA 12.2M
__DATA/__OBJC 244K
__IMAGE 528K
__IMPORT 36K
__LINKEDIT 43.5M
__OBJC 2640K
__OBJC/__DATA 160K
__PAGEZERO 4K
__TEXT 170.1M
__UNICODE 544K
mapped file 81.5M
shared memory 5824K
TOTAL 576.1M
TOTAL, minus reserved VM space 576.0M
Last edited by Michael_Graubart on Fri Apr 24, 2015 4:21 pm, edited 2 times in total.
Reason: wrap crash log in code tags for readability
Michael_Graubart
Here is the second one:
Code: Select all
Process: Audacity [283]
User ID: 501
Date/Time: 2013-09-08 19:58:08.402 +0100
Report Version: 10
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x000000000bbffff4
VM Regions Near 0xbbffff4:
shared memory 000000000bbfc000-000000000bbfd000 [ 4K] rw-/rw- SM=SHM
MALLOC_TINY 000000000bc00000-000000000bd00000 [ 1024K] rw-/rwx SM=PRV
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 libsystem_c.dylib 0x94bc9b50 memmove$VARIANT$sse42 + 403
Thread 2:
Thread 3:
Thread 4:
Thread 5:
Thread 6:
Thread 7:: com.apple.appkit-heartbeat
Thread 8:: com.apple.CoreAnimation.render-server
Thread 9:: CVDisplayLink
Thread 0 crashed with X86 Thread State (32-bit):
eax: 0x0bc6fc01 ebx: 0x0482db80 ecx: 0x00000034 edx: 0xfff90380
edi: 0x03315d40 esi: 0x0bc6fc94 ebp: 0xbfffdc48 esp: 0xbfffdc40
ss: 0x00000023 efl: 0x00010282 eip: 0x94bc9b50 cs: 0x0000001b
ds: 0x00000023 es: 0x00000023 fs: 0x00000000 gs: 0x0000000f
cr2: 0x0bbffff4
Logical CPU: 1
Binary Images:
0x2fb1000 - 0x2fb1ff5 +cl_kernels (???) <92FA41F0-F052-44E1-B11D-69F0822734CF> cl_kernels
0x4c1e000 - 0x4c1fff1 +cl_kernels (???) <BBE5920B-2FB4-45E4-8CC9-E230FE946D20> cl_kernels
0x4c21000 - 0x4c33fd8 +com.smartelectronix.magnus.Ambience (1.0.4 - 1.0.4) /Library/Audio/Plug-Ins/Components/Ambience.component/Contents/MacOS/Ambience
0x4c8b000 - 0x4c8bfff +cl_kernels (???) <6D1C9ECA-F152-4F20-BF1B-FA2F71B5818B> cl_kernels
0x4c90000 - 0x4c91ff5 +cl_kernels (???) <B3D5C9F6-FF01-4109-9358-905AD23E1E7E> cl_kernels
0x4f4d000 - 0x4fbffff +com.DivXInc.DivXDecoder (6.4.0 - 6.4.0) /Library/QuickTime/DivX Decoder.component/Contents/MacOS/DivX Decoder
0xc19e000 - 0xc230fff unorm8_bgra.dylib (2.2.16) <1298D118-0B14-3F3D-B2CA-348A1C67183E> /System/Library/Frameworks/OpenCL.framework/Libraries/ImageFormats/unorm8_bgra.dylib
0xc242000 - 0xc2c2fff com.apple.iLifeMediaBrowser (2.7.4 - 546.7) <130581CE-0699-3524-B487-726353FDDF96> /System/Library/PrivateFrameworks/iLifeMediaBrowser.framework/Versions/A/iLifeMediaBrowser
0xd841000 - 0xd9d5ffa GLEngine (8.9.2) <73F967E8-16C2-3FB2-8C04-293EB038952D> /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine
0xda0c000 - 0xdb8dfff libGLProgrammability.dylib (8.9.2) <B7AFCCD1-7FA5-3071-9F11-5161FFA2076C> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
0x8fe4d000 - 0x8fe7fe57 dyld (210.2.3) <4D38DEED-9837-3202-B8E9-41272D01EA2C> /usr/lib/dyld
task_for_pid: 14
thread_create: 0
thread_set_state: 0
task_for_pid: 0
thread_create: 0
thread_set_state: 0
task_for_pid: 340
thread_create: 1
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=213.5M resident=125.4M(59%) swapped_out_or_unallocated=88.1M(41%)
Writable regions: Total=176.9M written=17.9M(10%) resident=53.2M(30%) swapped_out=0K(0%) unallocated=123.7M(70%)
REGION TYPE VIRTUAL
CG image 64K
CG raster data 104K
CoreAnimation 1500K
CoreImage 4K
CoreServices 1652K
IOKit 27.8M
MALLOC 84.0M
Memory tag=240 4K
Memory tag=242 12K
Memory tag=249 156K
Memory tag=35 2964K
OpenCL 40K
OpenGL GLSL 1552K
Stack 68.6M
VM_ALLOCATE 16.5M
__DATA 12.2M
__DATA/__OBJC 244K
__IMAGE 528K
__IMPORT 36K
__LINKEDIT 43.5M
__OBJC 2640K
__OBJC/__DATA 160K
__PAGEZERO 4K
__TEXT 170.1M
__UNICODE 544K
mapped file 81.5M
shared memory 7364K
TOTAL 567.6M
TOTAL, minus reserved VM space 567.5M
Reason: wrapped crash report in code tags for readability
- Quality Assurance
Re: Audacity 2.0.4 still crashes
@ Michael_Graubart, your first 2.0.4 crash report is different (the thread writing the log did not crash):
pthread 0x200ac8e4
Do you recall what happened there - did you actually manage to import a file?
Have you tried http://www.gaclrecords.org.uk/test-buil ... -alpha.zip to see if removing logging makes 2.0.4 usable?
pthread 0x200ac8e4
