Audacity 2.0.4 does not launch
M.Klimek
Post by M.Klimek » Sun Sep 08, 2013 7:06 am
Unable to load with Microsoft Windows XP, Professional Version 2002, service Pack 3.
I installed audacity-win-2.0.4.exe
After I was unable start Audacity 2.0.4. I uninstalled Audacity and tried a clean install with Audacity 2.0.4.
windows version
Windows Version.JPG (28.3 KiB) Viewed 1200 times
Reason: Topic spit to Windows forum and given relevant title
Re: Audacity 2.0.4 does not launch
Post by steve » Sun Sep 08, 2013 10:35 am
M.Klimek wrote:After I was unable start Audacity 2.0.4
Reboot your computer, then try re-installing and in the "Select Additional Tasks" screen, put a check in the "Reset Preferences" box. Complete the installation. On launching Audacity, a dialog should appear asking you to confirm if you want to reset preferences - select Yes to reset preferences.
Does that work?
If not, are there any error messages?
Please describe in detail what happens.
M.Klimek
Post by M.Klimek » Sun Sep 08, 2013 3:28 pm
I reinstalled Audacity Audacity 2.0.4.
When I launch Audacity, the CPU remains at 50%.
'No Visible Window Found In The Process'
CPU remains at 50%
Post by steve » Sun Sep 08, 2013 3:32 pm
M.Klimek wrote:I reinstalled Audacity Audacity 2.0.4.
Did you select "Reset Preferences"? That is important or reinstalling will make no difference at all (it may not make a difference if you reset preferences, but it is worth trying).
M.Klimek
Post by M.Klimek » Sun Sep 08, 2013 5:37 pm
I did select 'Reset Preferences' .
Regardless, when launched, the program does not have a window.
Should I try an earlier version?
Post by steve » Sun Sep 08, 2013 6:40 pm
M.Klimek wrote:Should I try an earlier version?
Audacity 2.0.3 is available here: http://code.google.com/p/audacity/downl ... =1&q=2.0.3
You should view using 2.0.3 as a temporary measure. It seems to affect only a few XP machines, which makes it difficult to track down the problem because we have not been able to reproduce the issue. When a solution is found I hope that you will be able to test it, which will then give you the benefit of the many improvements that have been made in Audacity 2.0.4.
Post by Gale Andrews » Sun Sep 08, 2013 10:15 pm
Please try the build in this topic http://forum.audacityteam.org/viewtopic ... 04#p222304 .
M.Klimek
Post by M.Klimek » Mon Sep 09, 2013 12:31 pm
Audacity 2.0.5-alpha-Sep 8 2013 is completely operable.
Thank you!
EarthSongWoman
Post by EarthSongWoman » Mon Sep 09, 2013 1:41 pm
Thank you for that new build - I was having a problem in XP where trying to run audacity just made my machine reboot. Now, with this build, it is sorted - thank you
