Audacity 1.2.x and 1.3.x are obsolete and no longer supported. If you still have those versions, please upgrade at
https://www.audacityteam.org/download/.
The old forums for those versions are now closed, but you can still read the archives of the
1.2.x and
1.3.x forums.
- Site Admin
Post
by steve » Mon Sep 09, 2013 8:30 am
Thanks KeyserS.
KeyserS wrote:BTW how long does it take to be 'unlocked' on this forum ? It's getting quite annoying to have to wait for every post to be approved...
Not long - in fact, as you are clearly not a spammer I've manually unlocked your account so your posts should appear immediately.
The decision to make new users post subject to moderation was a step that we took reluctantly but was necessary to handle the huge amount of spam that was being posted. We do our best to keep this a safe and pleasant corner of cyberspace
KeyserS
Post
by KeyserS » Mon Sep 09, 2013 11:28 am
Judging by some other posts, it seems v2.0.4 doesn't like when there are several audio devices.
I've completly forgotten about the ATI audio abilities which are used by HDMI audio.
FYI foobar2000 gives me the choice between "KS Realtek HD Audio output" and "KS ATI HD Audio rear output", among DS outputs, but if I select the latter I'm getting this error message:
Code: Select all
Unrecoverable playback error: KS output error: error opening device
But since it's used by HDMI I wonder if KS does make sense in this case.
steve wrote:I've manually unlocked your account
Thanks!
- Quality Assurance
Post
by Gale Andrews » Mon Sep 09, 2013 12:20 pm
KeyserS wrote:I've completly forgotten about the ATI audio abilities which are used by HDMI audio.
Code: Select all
So if you go to
Windows Sounds and Audio Devices is the ATI HD Audio rear output a separate playback device? If so and you disabled or uninstalled it (probably you'd have to do it in Device Manager) then 2.0.4 might launch.
KeyserS
Post
by KeyserS » Mon Sep 09, 2013 12:36 pm
Yes, it is.
Gale Andrews wrote:If so and you disabled or uninstalled it (probably you'd have to do it in Device Manager) then 2.0.4 might launch.
Sorry but it's the HDMI device driver so I'm obviously not going to remove it. It's up to Audacity to deal with it instead.
- Quality Assurance
Post
by Gale Andrews » Mon Sep 09, 2013 1:05 pm
KeyserS wrote:Gale Andrews wrote:If so and you disabled or uninstalled it (probably you'd have to do it in Device Manager) then 2.0.4 might launch.
It's up to you of course, but I understood you might not be using that HDMI output.
The ultimate answer hopefully won't be to remove WDM-KS, but step over it gracefully if it doesn't work for some device. WDM-KS might even work fine with your standard input for all we know. The point of putting it in 2.0.4 was that it allows you to record with extremely low latencies (similar to those of ASIO, which we cannot ship for licensing reasons).
KeyserS
Post
by KeyserS » Mon Sep 09, 2013 2:26 pm
The question remains: does using KS on HDMI make sense ? Is it even possible ?
I have googled a bit about that and it's unclear.
- Quality Assurance
Post
by Gale Andrews » Mon Sep 09, 2013 3:25 pm
KeyserS wrote:The question remains: does using KS on HDMI make sense ? Is it even possible ?
The device drivers of that HDMI device have apparently determined that KS does make sense, but neither Audacity or Foobar2000 can use HDMI with that kernel streaming. That is not Audacity's or Foobar2000's fault (it is Audacity's fault that it won't launch with HDMI kernel streaming).
Have you tried
updating drivers for that ATI HDMI device?
Kernel streaming is valid with S/PDIF so in principle I think it ought to work with HDMI. Whether your HDMI interface is too modern for the WDM/KS interface, or vice-versa, or the problem lies in your ATI drivers, only you can figure out.
zalain212
Post
by zalain212 » Sat Sep 14, 2013 1:24 pm
Sorry for my late response... I finally found the time to try the new build, and it works perfectly for me also !
Great work from you guys to troubleshoot this and find a solution so quickly !
KeyserS
Post
by KeyserS » Sat Sep 21, 2013 1:00 pm
Frankly it would be nice to have a maintenance release, Audacity should run showing an error message but not to hang like this.
Can we expect it ?
- Quality Assurance
Post
by Gale Andrews » Sat Sep 21, 2013 1:06 pm
KeyserS wrote:Frankly it would be nice to have a maintenance release, Audacity should run showing an error message but not to hang like this.
Can we expect it ?
I think the instructions on
http://forum.audacityteam.org/viewtopic ... 46&t=74470 are clear. You can use the posted 2.0.5-alpha as a 2.0.4 "maintenance release".
Would you like to help us test solutions as we develop them?
