Audacity on Boot up.
Help for Audacity on macOS.
sus4
Post by sus4 » Sat Sep 07, 2013 12:44 pm
Since I got my new Mac Mini v. 10.8.4. Audacity has been opening up on boot up. I don't have " Open At Login" checked. Anyone know how I can stop this?
Thanks
Re: Audacity on Boot up.
Post by Gale Andrews » Sat Sep 07, 2013 1:28 pm
Are you using the latest 2.0.4 from http://audacityteam.org/download/mac ?
Are you running Audacity from the DMG? If so, that's a bad idea. Please see "Installation instructions" on the above page.
sus4
Post by sus4 » Sat Sep 07, 2013 2:08 pm
Gale,
I just downloaded 2.0.4 and it corrected the problem.
Thanks for your help.
Sus4
billw58
Post by billw58 » Sat Sep 07, 2013 2:11 pm
Go to Apple Menu > System Preferences, click your account in the list, then click "Login Items". Make sure Audacity is not in the list. If it is, select it then click the "-" (minus) button to remove Audacity from the login items.
-- Bill
sus4
Post by sus4 » Sat Sep 07, 2013 2:32 pm
Bill,
I didn't think of that, but I just did and Audacity was not on the list.
Anyway, it was good to upgrade to 2.0.4
Thanks
billw58
Post by billw58 » Sat Sep 07, 2013 7:41 pm
The other thing to look for is the "reopen windows when logging back in" option in the restart/shutdown dialog.
-- Bill
sus4
Post by sus4 » Sat Sep 07, 2013 8:45 pm
Thanks again guys. I appreciate it.
sus4
