Drag and drop not working
Please state:
Please state:
spacesword
For anyone that's using Lubuntu 13.04 / PCManFM 1.1.0, if you find that dragging and dropping files into Audacity isn't working, it appears the bug is with PCManFM itself and not Audacity, just so you know.
Re: Drag and drop not working
There has been a bug fix to drag and drop behaviour in PCManFM 1.1.1 so hopefully this will be OK in the next update.
