Exported Spectrum overwrites existing file.
This read-only archive contains discussions from the Adding Feature forum.
New feature request may be posted to the Adding Feature forum.
Technical support is available via the Help forum.
Edgar
Forum Crew
Re: Exported Spectrum overwrites existing file.
Post by Edgar » Tue Nov 12, 2013 5:47 pm
While it's probably a tossup, I think I would put this into the Warnings Preference panel. Otherwise, this looks really good.
Edgar
Forum Crew
Post by Edgar » Tue Nov 12, 2013 5:54 pm
The patch applied properly and work as advertised – testing on Windows 7 only.
Post by steve » Tue Nov 12, 2013 6:12 pm
Edgar wrote:While it's probably a tossup, I think I would put this into the Warnings Preference panel
That occurred to me too. It depends on whether you are looking to "stop the warnings about overwriting" or to "configure the export options". I decided to go with the latter because, like when overwriting an audio file, it's not a warning where you can say "don't show this again". The export preference allows you to select "always overwrite mode" rather than the user "cancelling the warning". Not a great distinction I know, but as you say it's a tossup for one or the other, and that is my butterfly.
Edgar wrote:The patch applied properly and work as advertised – testing on Windows 7 only.
Excellent. Thanks for testing.
I think the wording needs a bit of tweaking, but otherwise I'm happy with this solution.
