4 part vocal tracks help pleas
Feedback and Reviews for Audacity 2.x
This board is ONLY for general feedback and discussion about Audacity 2.X.
If you require help, or think you have found a "bug", please post on the forum board relevant to your operating system.
fanznanz
Post by fanznanz » Mon Sep 02, 2013 6:20 pm
I am new to this program so I could use some adivce. I would like to take a 4 part vocal track and split it into four separate tracks so that I could mute one of them for rehearsal purposes. OR I could import the four separate tracks to mute one then blend the four into one. Any suggestions. I have read the dubbing tutorial , but I do not need a voice over procedure. :cry: Any help would be so appreciated. Thanks. :)
Re: 4 part vocal tracks help pleas
Post by steve » Mon Sep 02, 2013 6:54 pm
fanznanz wrote:I would like to take a 4 part vocal track and split it into four separate tracks so that I could mute one of them for rehearsal purposes.
Unmixing the ingredients of a cake rarely works.
fanznanz wrote:OR I could import the four separate tracks to mute one then blend the four into one.
Yes that will work if you have recordings of the separate voices. Just import the tracks and use the track mute buttons to mute those voices that you don't want to hear, then export (File menu) to create a new file.
