please tell me how
RIVERPOSIE
please tell me how
Post by RIVERPOSIE » Wed Nov 26, 2008 6:30 pm
I am not very good with computers..I was told by a friend that this program would help me..I want to get a song from one of my files & set it so that it will play over & over again ( repeat itself) so that I can attach it to a movie & when the song ends, it will start over again & continue to play till the slide show is over .. I dont have any idea how to use Audacity or what it is all about...Can someone please just tell me how to do what I am requesting in a step by step instruction. Thank you all very much Bob
Re: please tell me how
Post by steve » Thu Nov 27, 2008 2:17 am
RIVERPOSIE wrote:I am not very good with computers..I was told by a friend that this program would help me..
To familiarise yourself with Audacity, go through some of the tutorials and you will soon be able to do loads of stuff with it: http://audacityteam.org/wiki/index.php?title=Tutorials
To repeat a track or section. select what you want to repeat, then from the "Effects" menu select "Repeat". In the dialogue box that appears, enter the number of times that you want it to repeat and then click "OK".
stearman65
Post by stearman65 » Thu Nov 27, 2008 11:44 pm
If you have loaded your music into audacity, you need to export it as an MP3 file, then load the file into you slide show software, If the music is alraedy on your computer as an mp3 file you can load it straight into PTE. If you are using Pictures to Exe, there is a tab on the project options button named music, tick the repeat music after playing box.
Stearman65
RIVERPOSIE
Post by RIVERPOSIE » Sat Nov 29, 2008 1:58 am
Thanks again so much..I spent all day working with this & did fairly well...Now I have a problem with what you told me...You said to repeat, i need to select what i want...Here i am lost...how & what do i do to select what I want..I already have the tune opened up on the program but when i click on Effects the repeat is not available to click on....i think i am not doing something right to select..What do you mean by select & how do i do that...Thnaks bob
Post by kozikowski » Sat Nov 29, 2008 2:22 am
If you click and hold inside the timeline--the blue waves--and drag sideways, that portion of the song will change color. That colored section has been "selected."
RIVERPOSIE
Post by RIVERPOSIE » Sat Nov 29, 2008 3:40 am
kozikowski wrote:If you click and hold inside the timeline--the blue waves--and drag sideways, that portion of the song will change color. That colored section has been "selected."
O.K. I did that and it changed color but when i went up to Effects, it wouldnt still let me do anything...i also tried the Ctrl + R and that didnt do anything either....maybe i dont know what the time line is you are talking about
Post by steve » Sat Nov 29, 2008 4:22 am
