Does saving a project alot mess it up
BRManson5
Post by BRManson5 » Fri Aug 30, 2013 5:00 pm
Hello just wondering if saving my project im working on a lot will make it more vulnerable to mess up? Thanks :geek:
Re: Does saving a project alot mess it up
Post by Gale Andrews » Fri Aug 30, 2013 5:20 pm
Please try reading the responses you have already received to your multiple posts on the same subject, for example http://forum.audacityteam.org/viewtopic ... 23#p221223 .
