Your guess was correct, Audacity is being clever and reusing some of the same data multiple times.
Opening up the SleepMachine3.aup file in a plain text editor, here's the first part of the first audio track:
Code: Select all
<wavetrack name="dishwashercd" channel="0" linked="1" mute="0" solo="0" height="151" minimized="0" rate="44100" gain="1.0" pan="0.0">
<waveclip offset="0.00000000">
<sequence maxsamples="262144" sampleformat="262159" numsamples="1385522347">
<waveblock start="0">
<simpleblockfile filename="e000051f.au" len="144326" min="-0.64644" max="0.599908" rms="0.156431"/>
</waveblock>
<waveblock start="144326">
<simpleblockfile filename="e0001fc2.au" len="158591" min="-0.64644" max="0.599908" rms="0.164283"/>
</waveblock>
<waveblock start="302917">
<simpleblockfile filename="e0001ef8.au" len="158591" min="-0.64644" max="0.599908" rms="0.164026"/>
</waveblock>
<waveblock start="461508">
</waveblock>
<waveblock start="605834">
<simpleblockfile filename="e000106d.au" len="158591" min="-0.64644" max="0.599908" rms="0.164283"/>
</waveblock>
<waveblock start="764425">
<simpleblockfile filename="e000107b.au" len="158591" min="-0.64644" max="0.599908" rms="0.164026"/>
</waveblock>
<waveblock start="923016">
</waveblock>
<waveblock start="1067342">
<simpleblockfile filename="e0001b6e.au" len="158591" min="-0.64644" max="0.599908" rms="0.164283"/>
</waveblock>
<waveblock start="1225933">
<simpleblockfile filename="e0001ab6.au" len="158591" min="-0.64644" max="0.599908" rms="0.164026"/>
</waveblock>
<waveblock start="1384524">
</waveblock>
<waveblock start="1528850">
Code: Select all
Note that the file e000051f.au is used 4 times in this section.
