To put it short, when I try to do an adjustable fade-in, the program ALWAYS does a regular fade-in instead.
I am using the Apple version.
Almost forgot! A fade-in bug in 2.0.3
This board is ONLY for general feedback and discussion about Audacity 2.X.
If you require help, or think you have found a "bug", please post on the forum board relevant to your operating system.
KlarkKentThe3rd
Re: Almost forgot! A fade-in bug in 2.0.3
What settings are you using in Adjustable Fade?
KlarkKentThe3rd
I tried "cosine out" and "s curve". Both resulted in the same regular fade-in. I did that about 5 times before giving up.steve wrote:What settings are you using in Adjustable Fade?
That was about 3 months ago, but I was already using 2.0.3
Perhaps you had the "Linear" preset selected (bottom control).
The presets override the other controls.
I can't really draw any conclusions unless you describe exactly what you were doing (including all 6 of the settings).
waxcylinder
Worked ok for me when I tested
