Problems silencing/trimming
Please state:
forestcre
Post by forestcre » Sun Aug 18, 2013 12:11 pm
Dear all,
when I select a region of audio and try to silence or trim it, the action is applied incorrectly. Say for instance that I select 1 sec of audio and try to silence it: 6 sec of audio are silenced, and not equidistant around the selection. If it select 1 sec of audio to trim, it trims to the correct region, but the first few seconds of the selected audio are silenced.
Even more bizarrely, this happened on two machines. Machine 1 I can't remember but both run Slackware. This machine has Audacity 2.0.2 on Slackware 14, built from the slackbuilds.org script.
The projects and audio files came from an intern running OSX and an unknown version of Audacity. They load and play correctly.
Bests,
Jason
forestcre
Re: Problems silencing/trimming
Post by forestcre » Sun Aug 18, 2013 12:38 pm
Update:
The issue seems to be with any action performed---the resultant audio has the first X seconds silenced! For example copying and pasting a region gives a new clip with about 3.5 seconds silenced at the beginning.
J
Post by steve » Sun Aug 18, 2013 7:29 pm
Are you sure that the first few seconds play correctly?
Do you have read/write access to the project _data folder?
