Apogee Duet 2 Won't Show Up in Device List
Can someone help me? I can't get my Duet 2 to show up when I look up devices for my projects. Is it not compatible with Audacity?
Re: Apogee Duet 2 Won't Show Up in Device List
Never mind I fixed my problem! Just had to reset the duet but unplugging it from the comp and then hold down on the wheel and plug it back in to reset it.
In general, Audacity will not look for any devices after it starts. Restarting Audacity after you plug something in can work wonders as can Transport > Rescan Audio Devices if you don't feel like waiting.
